Making Addins For Power Graphic 2 Fx's
Posted 18 December 2012 - 08:59 PM
Posted 18 December 2012 - 10:12 PM
http://casiopeia.net...raphic 2#p12604
EDIT:
If you want to get started with the sdk, here it is: http://edu.casio.com...dk/9860sdk.html
and the manual for it: https://edu.casio.co...rters_guide.pdf
After some extensive searching it seems that as long as you use syscalls and no hardware specific stuff, you'll be ok.
Posted 21 December 2012 - 03:12 PM
** L2011 (E) Invalid parameter specified in option "input" : ""C:\Program Files (x86)\CASIO\fx-9860G SDK\OS\FX\lib\setup.obj""
Posted 21 December 2012 - 03:16 PM
Posted 21 December 2012 - 03:19 PM
Posted 21 December 2012 - 03:28 PM
If the link doesn't work or goes very slow, sorry. Anova's been acting up this morning.
And here's the code (I was just modifying the example SDK code) : http://anova.57o9.or.../mclandcode.txt
Posted 21 December 2012 - 03:30 PM
I had the same error. Try to install the SDK on a device where you don't need administrative privileges.
Posted 21 December 2012 - 10:40 PM
Posted 22 December 2012 - 06:56 AM
Edited by Casimo, 22 December 2012 - 06:58 AM.
Posted 30 December 2012 - 12:50 PM
Has anyone have been successful in installing the official SDK to a 64-bit Windows?
Posted 30 December 2012 - 01:32 PM
Edited by Casimo, 30 December 2012 - 03:19 PM.
Posted 06 January 2013 - 12:13 PM
Posted 06 January 2013 - 12:19 PM
- MicroPro and Casimo like this
Posted 06 January 2013 - 12:30 PM
Posted 06 January 2013 - 12:34 PM
Posted 27 February 2013 - 05:39 PM
So deinstalled and ran the setup as administrator and then installed on a ram disk. Then I had to take control of the directory and then ran the SDK and the empty project did compile.
What a nice surprise and my thanks to Casimo.
Now to start learning how to produce the add on.
Posted 27 February 2013 - 06:14 PM
I can compile and it produces a G1A file but not a G1M file that seems to be the extension for an add on.
I have assumed the SDK can produce the G1M but can some nice person tell me how.
Paul
Double post merged by moderator:
HI,
Please ignore my last post, fully understand now, G1A is suitable as an add on, can see it on my 9860.
Sorry guys.
Paul
Posted 27 February 2013 - 06:43 PM
[edit ][ /edit] tag. EDIT:
| Ontopic: this is a great little guide right here: http://www.casiopeia....php?f=2&t=1483 Kudos, Casimo |
