Edited by HuckleberryCatfish, 01 March 2013 - 05:37 AM.
Fx-9860Gii How To Get Sum Total For Numbers In Spreadsheet Column?
HuckleberryCatfish
, Mar 01 2013 05:34 AM
spreadsheet
Posted 01 March 2013 - 05:34 AM
I have made a spreadsheet with 10 rows and 5 columns. I need to add up the numbers in order to get a total at the bottom of each column. (adding the numbers vertically) I read the spreadsheet chapter in the user manual. But I can't find any instructions for a way to make the calculator give a total for the numbers in a column. Please help! Thanks.
Posted 01 March 2013 - 01:40 PM
If you have a column from say A1 to A4 and you want the sum in A5, then move the cursor to A5 and type any number, then press delete and press
F5' />,
F5' /> and then type A1:A4 and press
EXE' />.
It will put the sum in that cell.
Also tagged with one or more of these keywords: spreadsheet
Programming →
Casio Basic →
input results in a spreadsheet and display in the end (programing)Started by 1q2w3e4rr , 29 Nov 2017 |
Calculators →
Classpad →
Graphing A Function And Spreadsheet Data Simultaneously?Started by AussieGuy , 12 Jan 2014 |
