"locked Or Protected", "variable In Use" Errors
Posted 18 March 2013 - 09:17 AM
The last time this happened I deleted the entire program and re-keyed it in from scratch. But there must be some easier way!
What would cause this loop of errors, and how can I avoid it in future, and get out of it now?
Thanks,
-A.
Posted 18 March 2013 - 12:52 PM
Posted 18 March 2013 - 08:55 PM
Thanks,
-A.
Posted 19 March 2013 - 01:40 AM
Posted 19 March 2013 - 04:31 AM
I got round the issue yesterday of the "Variable in Use" error, by doing a full reset of the device.
-A.
Posted 19 March 2013 - 01:56 PM
I only have access to the handheld calculator, not to any computer emulator, and so all my programming is done on the device itself. Can I use Lua like this?
I think so, yes.
That's good, but it is sort of weird that that error would appear. Is it in the owner's manual?
Posted 19 March 2013 - 11:12 PM
-A.
Posted 20 March 2013 - 12:13 AM
Posted 22 March 2013 - 05:58 PM
I'm recently seeing topics very late.
Opening and saving the program file in Program should have unlocked it; it's strange it didn't. Unlocking the file is easy using the sdk programming (maybe if you told the path of the file I could write a tiny add-in to do it). This bug happens rarely, so hopefully you won't need to full reset the calc anymore.
Instead of deleting the file and re-keying, you could Copy-Paste the contents in a new program file.
flyingfisch mentioned CPLua, you can find it here: http://community.cas...orum/61-cplua/ and yes, it's fully on-calc. ClassPad Basic is good for easy programs, it's the native and somewhat easier language. For programming anything serious with nice UI, fast speed and stuff, CPLua is the best choice.
