I have some questions for you :
here is my program :
?->N
Int N->I
Frac N->F
For 1->D To 1000
F×D->N
If Abs (Int (N+.5)-N)<1[size=1]E[/size]-10×D
Then Int (N+.5)->N
Break
IfEnd
Next
I[i][a b/c][/i]N[i][a b/c][/i]D[i][a b/c][/i]
I have a problem with "size" (line 6) I don't know how to get it, it is not in the "character menu" and its not in the
![<span class=](/dot/public/style_emoticons/default/SHIFT.jpg)
![<span class=](/dot/public/style_emoticons/default/4.jpg)
I also have a problem with the last line, do I have to writte it with the letters of the character menu (I mean for a,b,c,i) ?
Thanks a lot !
scientifix
Edited by scientifix, 20 April 2013 - 03:39 PM.
