If A=2 And B=1
Then "You just get past the lion."
Goto S
IfEnd
If A=2 And B=0
Then "You run out of energy."
"The lion catches you! You die."
"THE END"
Stop
IfEnd
Note that the EXE arrow and little pause staircase thing (don't know what they're actually called) is there - I just don't have it on my keyboard to show you all. I'm basically trying to make a text based game utilizing variables and if statements. In this particular part, I'm trying to make it so that if you have completed a certain action previously [B], then you get a certain outcome. [A] is the player's input (go back/run past the lion). It doesn't come up with a syntax error but it completely seems to skip the 'and' part of the statement. Also, I can't seem to start out under a label with an 'if' statement. I've also tried using an 'else' statement, but whenever I do it skips to the else bit and seems to disregard the 'if' statement altogether. Whenever I make these chains of if statements normally, it works - it's just when I use the 'and' or try to put if statements in if statements. Please help!
Edited by Aether, 05 February 2014 - 04:12 AM.
