Hi... I really appreciate your effort...
Actually, using the comptoRec built-in function, the results came out correctly... But I have already made some other calculations mixing complex numbers in both formats, rectangualr and polar and the results always came out correct.
And I also found out that the subscript numbers next to I are not very friendly in this situation. Actually even if I used the built-in function comtoRect and used the I index 1, 2 or whatever index i used, the results are not correct.
I ended up using regular variable letters like x, y, z and t!
The results for I1, I2, I3 and In are approximately:
I1=12.52|
50.64�I2=14.36|
-136.4�I3=7.03|
113.8�In=8.16|
130.54�What I have done was the following:
Edited by PsySc0rpi0n, 10 April 2014 - 09:41 AM.
