My CP-fx400 is not computing complicated integrals. When I say complicated, it's not really that complicated. For example, the integral e^(7x)*x^(-11) just comes back as a solution the same as I entered it (with fdx symbols around it). Some simpler ones work ok.
I did also notice that if I entered a sum like 8^3 the solution would come back as 8^3 not 512. I set it back to default format which got the simple stuff like 8^3 working right but not processing the integrals.
Any fix for this?
Classpad 400 Not Processing Complicated Integrals.
Splint
, Apr 25 2014 12:26 AM
Posted 25 April 2014 - 12:26 AM
Posted 25 April 2014 - 06:50 PM
The solution of integral is really complicated based on wolframalpha
https://www.wolframa...nt(e^(7x)/x^11)
In case of 8^3, switch the calc from Assist to Alg and you get the result 512.
