Flash100 1.30 doesn't create a drive, for internal reasons.
Flash100 1.30 communicate only with GComm 0.85b or later.
GComm 0.85b can't edit graphically an icon and doesn't remove an icon (currently).
Flash100 is translate in French (default), English, Deutsh and Spanish.
Currently GComm is only in French.
The communication with GComm 0.85b is faster than old version.
Flash100 help:
- To send/receive a drive to your AFX using GComm, select the drive(s) you want to send/receive in flash100, then press F2 or select receive in GComm and press F5 (send)/F6(receive) on Flash100. It's the same thing with Casio Protocol.
- Flash100 : In Option Window you can select Casio Protocol and GLink Protocol for GComm. With Glink protocol you can choose speed (56K or 112K).(By Default : 112K in F100 & GComm)
GComm help:
In InputBox (text) or chat :
- In main menu press
- In "file manager" and "Send Ram menu",
Flash100 :
Dll Qt 3.1.2 Pro
http://g100storage.f...ta/qt-mt312.rar
Exe + languages (without Upx)
http://g100storage.f...ta/Flash100.rar
GComm :
