Hi All,
I'm a hydrographic surveyor and have been using FX603P since long long time ago.
Recently decided to retire my old calculator and upgrade to the fx-FD10Pro.
I thought it'll be as simple as the fx603p...I was wrong.
The MinXX is gone, an I have problem understand how this new calculator handle its memory ;-(
Can someone help me convert a simple program as below :-
“Polar to Rect” PAUSE “Stn/E?” HLT Min01 AC “Stn/N?” HLT Min02 AC LBL1 “Bearing?”GSBP10 Min03 ’” PAUSE AC “Distance?” HLT PR MR03 = Min04 XY Min05 MR01 + MR05 = FIX3 “Easting” HLT AC MR02 + MR04 = FIX3 “Northing” HLT AC GOTO1
P10
Min1F INT + (MR1F FRAC x 2 10x) Min1F INT 60 MR1F FRAC 36 =
