I just found an old fx-570s. I found out that it is on degree mode. Is it normal? Thanks!
Posted 07 June 2016 - 11:05 AM
Posted 09 June 2016 - 09:28 AM
That is relative. You must configure the calculator in the angle unit that you need.
I think that in most cases, the degree mode is the normal mode.
360 degrees = 1 complete circunference
2pi radians = 1 complete circunference
It's your choice!
PD: I don't know if it is possible to reset some old calculators like your's, because the configuration is really simple. Take a look to the manual.
