How To Print Spread Sheet Created On Fx-9860Gii?
Best Answer pan.gejt , 26 June 2016 - 03:55 PM
The spreadsheet file, which were created in calculator, can be saved as csv.
Start FA-124, connect calculator, transfer the file to the FA-124 - drag and drop the file from the left window to the right window, select Default directory, new directory S-Sheet with file inside is created.
Click on the transferred file in FA-124 window and select File - CSV - Save as CSV.
Go to the full post
#1 Amir79
Amir79
  • 2 posts
    FX-9860GII SD poer graphic 2
Posted 26 June 2016 - 11:35 AM
If you please, I need your support on how to print out the spread sheet witch created on my calculator fx-9860GII SD power graphic 2. , is there any work around to print this sheet on a paper or extract it as photo or something else?
I bought this calculator specially to do this task but I don’t know how to print the sheet out of the calculator.
Thanks in advance.
#2 pan.gejt
pan.gejt
  • 266 posts
Posted 26 June 2016 - 03:55 PM   Best Answer
  • Amir79 likes this
#3 Amir79
Amir79
  • 2 posts
Posted 27 June 2016 - 09:43 AM
Thanks for kind support
