Is it possible to write C software for this calc?
C for FX-9750G2?
Posted 02 March 2018 - 03:24 PM
Posted 07 March 2018 - 01:32 PM
No, there is no way to do that. You can write in casio basic but is limited in its use.
The only way you could write in c for that calculator is to port the fx-9850g2 os to the fx-9750. I would not do this because it can go wrong. It will either work, not work but still work or not work and the calc will not work
Posted 28 June 2018 - 05:04 AM
Just want to clarify, you could possibly "brick" or break your calculator forever if you try to put the fx-9860g2 os on to the fx-9750. I have done it on my calculator before and had no problems. You just need to make sure you use the correct os files and you will be fine. The risk of bricking your calculator is small if you do the correct steps.
