Help I Think I Broke My Calculator
Posted 04 April 2019 - 12:11 AM
- PhantomOverrideAlpha likes this
Posted 04 April 2019 - 02:53 PM
Tried hitting the reset button. Is there just a blank image when trying to turn on the calc?
Posted 05 April 2019 - 05:34 PM
Yes it doesn't turn on at all all there is is a blank image
Posted 09 April 2019 - 03:16 PM
Have you also tried new batteries?
Posted 09 April 2019 - 08:59 PM
Try to force your calculator into "OS Error" mode :
- press and hold the restart button on the back
- without releasing it, press and hold the [F2][4][AC] keys
- without releasing these 3 keys, release the restart button
- now only release the [F2][4] keys together
- wait a second
- now finally release the [AC] key
- press and hold the [9] key
- wait a second
- release the [9] key
- press and hold the [×] key
If the calculator turns on and shows you an "OS Error" screen, then it's not broken and you just need to reinstall a compatible OS.
Edited by critor, 09 April 2019 - 09:00 PM.
