fx 9750gii Graphics Problem
fx9750gii
11 replies to this topic
#1 Maverich40
Maverich40
  • 32 posts
  • Interests:Math, Programming, Astronomy, Space
    Casio fxCG500, fxCG10, fx-115ES, &c. and other brands.
Posted 27 February 2020 - 08:58 PM
I have a routine that plots a Mandelbrot Set fractal (famous image of "overlapping circles" on complex plane...)
When drawn on fx 9750 gii, I get columns of blank pixels using Plot X,Y  or other Graphics commands...
What do I need to do to either set up proper Plotting mode, or what Plotting Command should I be using that does
not space out the pixels....
(I can not be absolutely certain there might not be a small problem with Program itself, but it's kind of lengthy to be
 typing now.)
Thanks for any help!
//RadSurfer//
#2 CalcLoverHK
CalcLoverHK
  • 270 posts
  • Interests:FPS games, C.Basic
    fx-50FHII (2019/1/30)
    fx-991ESPLUS-2 (2023/12/22)
    fx-3650PII (2022/1/15)
    fx-9750GIII
    fx-9750GIII-WE
    fx-9860G Slim
    fx-9860GIISD
    fx-9860GIISD-2
    fx-CG20CN
    fx-CG50
    fx-CP400
    Graph Math+
Posted 28 February 2020 - 07:50 AM
Hi Maverich40
Use other variables other than X and Y. :)
Reference: (Planete-Casio)
Cheers
CalcLoverHK
Edited by CalcLoverHK, 28 February 2020 - 07:50 AM.
#3 Maverich40
Maverich40
  • 32 posts
Posted 28 February 2020 - 03:41 PM
Okay, so I replaced X, Y with G,H which were unused... I still get a mandelbrot plot that has blank columns spacing everything out! WHY?
Plot mode should be Connect or Plot? It takes over 20 minutes to draw this complete graphic on 9750gii (try it on a 7000g).
Why should simply plotting a Pixel be so non-intuitive and difficult!
//RadSurfer//
#4 CalcLoverHK
CalcLoverHK
  • 270 posts
    fx-9750GIII
    fx-9750GIII-WE
    fx-9860G Slim
    fx-9860GIISD
    fx-9860GIISD-2
    fx-CG20CN
    fx-CG50
    fx-CP400
    Graph Math+
Posted 28 February 2020 - 04:46 PM
@Maverich40
What is your View-Window setting?
#5 Maverich40
Maverich40
  • 32 posts
Posted 28 February 2020 - 05:22 PM
GridOff
AxesOff
G-Connect
Viewwindow A,B,9,D,C,9
-2.1 to A, 1.1 to B, -1.1 to D, 9 being Scale
No one has addressed differences in Plot, PlotOn, etc, or just why simple addressing of Graphics Screen Pixels is apparently not straightforward...
//RadSurfer//
#6 Lephe
Lephe
  • 17 posts
Posted 28 February 2020 - 05:50 PM
Each Plot/PlotOn will draw a single pixel on screen (except if you have G-Connect in which case consecutive Plot will render lines). As a side effect, X and Y will be modified.
It is hard for us to guess what's going wrong without seeing the relevant looping and drawing. Here's a program that fills the screen at your View-Window setting:
ViewWindow -2,1,0,-1,1,0
For -2→A To 1 Step 3÷128
For -1→B To 1 Step 2÷128
PlotOn A,B
Next:Next
You might have one unlucky blank column if you approximate the coordinates in an irregular way, but that's a simple fix.
Drawing pixels is straightforward, but bugs can be hard to find. Hang on!
#7 Maverich40
Maverich40
  • 32 posts
Posted 28 February 2020 - 06:13 PM
Here is a paste-bin which fully lists the Program, where it was originally discovered, and what changes were made
based on suggestion from this forum:
http://dpaste.com/2MHM0Z2
If you can get this to plot properly, PLEASE share.  :)
//RadSurfer//
#8 Lephe
Lephe
  • 17 posts
Posted 28 February 2020 - 06:41 PM
Have you noticed this line : (B-A) / 94 -> S ? This is clearly meant for a calculator with a screen of 94 pixels. The fx-9750G II has 128 pixels horizontally, and 127 are available to PRGM. You need to divide by 127!
#9 Maverich40
Maverich40
  • 32 posts
Posted 28 February 2020 - 07:24 PM
How could I have missed that! Thank you... Running it right now... it does appear to be more connected, hopefully I can take a photo of the finished image, provided it does not disappear when completed :-|}
Because of this Screen Size difference, I should be looking for possible other refinements?  Like I hope this fills most of the screen...
StoPict 1 as last statement,
and
RclPict 1 to be able to recall it, should Calc power down... excellent!
That's progress I guess.
For those into FreeBASIC, I did create a FB32 program that does this in colour:
https://i.imgur.com/O4wTnZe.png | https://i.imgur.com/fnaq4NE.png | https://i.imgur.com/m8EsMGa.png
Which is based on a Python3 script of all things... but that was easily converted to FreeBASIC!
//RadSurfer//
Edited by Maverich40, 28 February 2020 - 08:12 PM.
#10 Lephe
Lephe
  • 17 posts
Posted 28 February 2020 - 08:41 PM
Glad you got it to work! You can improve on this program by using actual complex numbers, which might speed up the computation by a noticeable amount.
#11 Hlib2
Hlib2
  • 145 posts
  • Interests:industrial electronics,
    graphing calculators
    fx-9860GII-2
    graph-100+
    fx-991DE_X
    ti-89_Titanium
    ti-voyage200
    ti-84+SE
Posted 28 February 2020 - 08:52 PM
The size of display in fx-9750gii is 127×63 pxl, therefore X-pitch (B-A)÷126 should be a rational fraction (Edit: decimal fraction without rounding error in the calculator) here too for this plottings.
Make:
-2.15->A:1->B:(B-A)÷126->S
and you will get what you want.
Edited by Hlib2, 28 February 2020 - 09:32 PM.
#12 Maverich40
Maverich40
  • 32 posts
Posted 28 February 2020 - 08:54 PM
https://i.imgur.com/...m/0tagf6T.jpg  It looks just a tiny bit "squashed" but otherwise just fine!  Using 63, 127 presently, and 40 iterations, might try playing with Iterations to see what I get...
Thanks everyone!
//RadSurfer//
Also tagged with one or more of these keywords: fx9750gii
