I'm trying to find a jailbreak for my calculator. I already have a way to write data to ram. Does anyone have a dump of the firmware and some technical information about the processor and instruction set?
Posted 28 September 2020 - 06:26 PM
Posted 29 September 2020 - 01:34 PM
* no. The software way to dump the ROM is tedious and involves a lot of trial and error.
Do it the hardware way is probably easier, if you figure out how to.
* yes, the CPU is nX-U8/100. You can find the instruction manual online.
It isn't possible to execute assembly code from RAM, however. (as far as I know -- if you figure out how to then you can post it here -- I'm sure someone will be interested)
If you can modify the hardware, why don't you just replace the internal with a new one?
Edited by user202729, 29 September 2020 - 01:34 PM.
Posted 29 September 2020 - 03:43 PM
Sounds nice ![]()
Posted 29 September 2020 - 04:03 PM
Is there an assembler to compile code or at least a manual to the instruction set?
Posted 29 September 2020 - 04:23 PM
Posted 30 September 2020 - 06:02 PM
Ok I'm writing my own one
Posted 19 October 2020 - 01:20 PM
I've started "hacking" my calculator and found some useful information about internal representation of data. I'll post it tomorrow. I'm also working on getting the rom image.
Wish me luck
Posted 22 September 2025 - 02:39 PM
Guys i am new to this calculator stuff and i bought an fx 991DEX and want to change the language from german to english but its locked
