Right Arrow key missing ? User Entry Prompt
#1 iqak
iqak
  • 2 posts
    fx-CG50<br />HP50g
Posted 02 August 2022 - 12:33 AM
fx-CG50 Prism
Would like to create some code that Prompts for Input Entries.
"<prompt>" ? -> <Variable Name> (page 308, (8-12) of the Software manual)
                     __
I cannot find a functional arrow key.
The printed arrow key, just above "AC/on" does not function.
Just trying to write some code that prompts the user to enter the known varuables.
Where is this key
#2 iqak
iqak
  • 2 posts
    fx-CG50&lt;br /&gt;HP50g
Posted 02 August 2022 - 09:24 PM
Apparently, the (Right) Arrow key functions beneath "Programming" NOT within Python.
#3 Just_A_Noob_Here
Just_A_Noob_Here
  • 17 posts
    FX-7400 GII, FX-570 ES
Posted 03 August 2022 - 10:07 PM
Hi iqak,
Don't take me seriously but, if your arrow key is damaged, then you could get the arrow key by:
I'm not sure how it works on cg-50 however you could
1. connect your calculator to pc,
2. get into <PROGRAM> folder
3. create a .g3m file (example.g3m)
4. write it (the program or that arrow character)
5. save it.
6. disconnect it
7. open that program/file on your calc editor
8. press Shift 8 (clip) select that arrow symbol and press copy F1
9. paste it for later uses 9
this should work, but the problem is... where do prism users write their programs on pc?
If it was monochrome series then you would get it from FA-124 program editor on top bar options.
I think there was some fan-made casiobasic IDE on planet-casio...
I believe my solution is over-complicated and a bad one.
Regards,
Nooblette
#4 HappyCalc
HappyCalc
  • 67 posts
  • Interests:Programming, On-Calc Programming(C.Basic), Gaming, Origami, Eating Chocolate
    fx-9860GII-2
    fx-CG50
Posted 07 August 2022 - 04:46 PM
Nooblette
Here are some solutions:
A: download a program from the internet (most should use variable assignment
B: write a program containing an identifiable sequence of letters (like "Hello World!"), then connect the prizm to your PC, open a hex editor, open <your calc>/@MainMem/PROGRAMS/<your program>.g3m, find your sequence of letters and replace one with the hex 0x0E (it's a "->" on your calculator) and unmount your calculator
C: Or simply write "->" into a file TEST.txt on your computer, connect your calculator and put that file into <your calc>/@MainMem/PROGRAMS/TEST.txt
D: Download C.Basic https://community.ca...e/?fromsearch=1 (it's much better than Casio Basic, has more feat
res, it's much faster,...), it has an integrated txt to g3m converter. So you can write "->" into a text file and convert it using C.Basic. Also in C.Basic you can select the right arrow in the char table (F6).
F: Ask the company where you bought your calc to send you a new one.
Did you mean they key isn't broken, you just wanted to make a prompt in python?
In python it's like on your computer. Just write
variable = input("prompt")
Edited by HappyCalc, 07 August 2022 - 04:46 PM.
