hi guys i need your help i have a casio z1ge 256k and i try to program in C.
here is my code
the code work , press run , then 1, then write 2 words and end.
the program is not complete but work.
Now i copy program in casio z1gr and all ok.
now i go menu C and L for load program but the casio show error:
P-CODE OVERFLOW
and i try to use command clear in basic like clear 10000,10000,35000
but not work.
if i delete 5 lines in the casio the program load and run good
i think the C have line delimited or some else.
can you copy my code and help?
thanks.
