* * * * * 1 votes
Casio Fx9860GIII self-test mode/debug/factory mode
self test mode factory mode debug mode debug help question casio fx9860GIII fx9860GIII fx-9860GIII fx-9860giii
#1 Joyful_Diamond
Joyful_Diamond
  • 3 posts
    Casio Fx-9860GIII
Posted 19 October 2024 - 05:32 AM
Hi there, does anyone know the self-test key combo for the Casio Fx9860GIII? I have an input/output error and my storage memory was full, so this is kind of a last ditch effort to try and save my calculator.
After this I might take it apart and yeah. Idk.
Many thanks!!
  • Joyful_Diamond likes this
#2 CalcLoverHK
CalcLoverHK
  • 264 posts
  • Interests:FPS games, C.Basic
    fx-50FHII (2019/1/30)
    fx-991ESPLUS-2 (2023/12/22)
    fx-3650PII (2022/1/15)
    fx-9750GIII (2020/6/13)
    fx-9860G Slim (2024/2/27)
    fx-9860GIISD (2023/3/27)
    fx-9860GIISD-2 (2024/2/5)
    fx-CG20CN (2023/2/12)
    fx-CG50 (2023/10/23)
Posted 20 October 2024 - 04:54 AM
The key combo is OPTN [x10x] + [AC/ON] while the calculator is off, and then F1 9.
Your problem sounds like a flash read/write failure like my fx-9750GIII that was discovered 4 years ago. Check the "Characteristic" section to see if any one of them matches your situation:
https://www.planet-c...mory-crash.html
#3 Joyful_Diamond
Joyful_Diamond
  • 3 posts
    Casio Fx-9860GIII
Posted 21 October 2024 - 06:43 PM
I don't know how to respond directly to you; I am new, but thank you very much for replying! I will test this out. The only thing is that I do not know how to execute a syscall. Do I just type it in? Much appreciated, thanks!
Also how am I meant to add the C.Basic file if my storage memory is unchangeable? I will at least try it, thanks!!!!! :) :) :)
#4 CalcLoverHK
CalcLoverHK
  • 264 posts
Posted 23 October 2024 - 02:07 AM
In C.Basic program editor, press Shift 5 and search "Syscall". Select it and type 0X205, then execute it.
That's the caveat of my workaround, as you cannot execute syscall in Casio Basic except you have an add-in that does it for you (in which C.Basic is probably the only add-in that theoretically supports all syscalls). If you don't have it after your storage is locked... well there is nothing you can do at the moment.
Have you installed any 3rd-party add-ins before?
Edited by CalcLoverHK, 23 October 2024 - 02:08 AM.
#5 Joyful_Diamond
Joyful_Diamond
  • 3 posts
    Casio Fx-9860GIII
Posted 23 October 2024 - 06:18 PM
Yes I have installed 3rd party add-ins, which I am 95% sure caused the problem. The program is called Terrario and there was a 35kB heap for the Casio fx9860GIII, but that was like a dumbed down version compared to the Casio fx9860GII version, which apparently had more memory. I think that the program filled up all the memory, but I don't know.
In the ROM TEST diagnostic area it says FLASH W/R ---- OK
So I don't know what the issue is :(
I used to have many add-ins but I deleted them to save space, plus did a few resets for school so my back-ups got removed :(
Basically everything that I could've done I removed on purpose or accidentally before this error occured :(
When I do factory testing it says CESG502 driver unavailable :(
Also there is a cash test but i can't select anything
Also tagged with one or more of these keywords: self test mode, factory mode, debug mode, debug, help, question, casio fx9860GIII, fx9860GIII, fx-9860GIII, fx-9860giii
