Help me to use Classpad
Posted 14 September 2003 - 12:49 AM
I am so happy today because Classpad 300 has been sold in Viet Nam, and i bought it yesterday. It cost $160 ( about 2.500.000 Dong { Dong is our currency}). It is not a small money for Vietnamese.
One problem is that the screen contrast is not bright. Is it because of the film protector installed on the classpad? May i take it out?
I am not usually connect to the Internet, so If you have some WEB about Classpad 300 or something special about Classpad Function, please tell me.
Cam on cac ban rat nhieu ( means Thank you so much).
Posted 14 September 2003 - 02:57 AM
classpad.org
casio.com
crimsoncasio.co.nr
I dont know anything about a film projector (translation error mabey?)...
Good luck with your classpad.
Posted 14 September 2003 - 11:14 AM
The film that I said is what install on the Classpad touchscreen.
(As you can see, My English is ... bad)
Posted 15 September 2003 - 02:35 AM
As far as resources, www.classpad.org has the most out there right now.
Posted 15 September 2003 - 11:58 AM
It seems to me that you have just joined this forum, right?
If you have something special about the classpad function, please tell me.
My Email is: noah_thunderstone AT yahoo.com
Thankyou again.
Posted 15 September 2003 - 12:39 PM
Posted 16 September 2003 - 06:08 AM
huhn_m is compleatly right. there is more and more users of classpad on this forum, and the forum is to share our knowlage and experience
Posted 16 September 2003 - 07:33 AM
Why ?Yes this protective plactic film can be taken off, but dont take off the protector, because you may loose your guarantee...
Posted 16 September 2003 - 11:27 AM
Not sure that this may happen in your country, but in my it will.
Posted 17 September 2003 - 01:21 AM
I was told, by a service guy in polish authorised casio service that when i'll remove protector and in future will have problems with touchscreen (maybe some death areas, where LCD doesn't react on pen) Service may refuse to repair it for free
If you are not suppose to remove it then how come it is designed to be removable?
Also, the display is so difficult to read with the protective cover I can't imagine they would refuse to repair it because you pretty much had no choice but to removed it.
I think that there was mentioned something about it in user guild, but i'm not sure.
I'd like so see this in the manual (I'll do a search and see what I can find). If they actually say this then they may try to hold you to this, but again, it is clearly designed as a REMOVABLE cover. How can they refuse to repair it because it is a REMOVABLE cover.
Posted 17 September 2003 - 07:32 AM
It's probably because when the protector get old, or damaged, so you can replace it
Posted 03 November 2003 - 08:09 PM
Most touch screen protectors, such as those that are sold for PDAs, have an adhesive that holds them in place. This one does not. That's a real problem. Without the adhesive, dust and such can get under the protector. The protector also slides about a little, so that dust can grind into the screen. It is a very poor design.
Does anyone know where I can get a replacement protector? As I said, mine is showing wear.
Posted 03 November 2003 - 08:12 PM
