need help. COM PORTS
Posted 20 September 2003 - 01:05 AM
it always say Fail to COM PORTS
help
Posted 20 September 2003 - 01:08 AM
Posted 20 September 2003 - 01:10 AM
FA-123
Add installer
both doens't work..
i don't think it's the program...
Posted 20 September 2003 - 01:13 AM
Sometimes you had transferred files?
Posted 20 September 2003 - 01:15 AM
it has been a long time since my last trans
i didn't make the cable
Posted 20 September 2003 - 01:20 AM
Or in the Tool menu, choose in "model type" the correct casio calculator model. Maybe your com port its damaged , try to use other.
There is a way to check the AFX com port, but you need another calculator of the same model (any algebra FX model I think so).
Posted 20 September 2003 - 01:24 AM
always FAIL to connect
will it be the com port damaged or the link dmaged?
*edit* huhn_m
Posted 20 September 2003 - 01:30 AM
"plug the link cable to your pc, without connecting your calculator. Start your pc if you not already done this, now start a program which let you manually write to you comports. Hyperterminal for example, this program is included in windows, if it's not installed get your Windows CD and install it.
Now, start the program and choose the comport you did connected your cable to. (usually com2 as com1 is mostly used for the mouse.)
bit per second: 9600 databits: 8 parity: none stopbit: 2 Xon/Xoff control: none.
Now, if you type something in the pc will send it to the cable. type something. Nothing should appear on your screen, if however it does appear on your screen you did something wrong and should check your cable again.
Ok nothing appears, now connect the top and middle of the 2.5 mm plug with each other. type something, your name for instance. If it appears correctly on your screen the data is send and received with succes! however of it doesn't appear (correct) there is something wrong and you should check everything again. (note: make sure you connected the top and middle firmly, but it usually already works if you put it between your lips. Where do those tinkles come from?)"
With this you will check the Com port of your PC and your link cable, if both are good your calc. serial port its damaged (Or maybe another member with more knowledge can help you later)
Posted 20 September 2003 - 01:31 AM
Posted 20 September 2003 - 01:36 AM
after checking the com ports in the Device Manager..
i got
COM ports ( COM 3)
Windows cannot determine the settings for this device. Consult the documentation that came with this device and use the Resource tab to set the configuration. (Code 34)
Click Troubleshoot to start the troubleshooter for this device.
Posted 20 September 2003 - 01:37 AM
I pressed CTRL' />+F6' /> and then i try to send it to the PC (with fa-123, screencapture option from the link menu), but my problem was not solved (I thought that my problem is another one).
Posted 20 September 2003 - 01:43 AM
Posted 20 September 2003 - 01:48 AM
Posted 20 September 2003 - 01:52 AM
" Fail to open COM port"
*edit* huhn_m
Posted 20 September 2003 - 01:56 AM
Posted 20 September 2003 - 01:57 AM
Posted 20 September 2003 - 01:58 AM
Posted 20 September 2003 - 02:00 AM
Posted 20 September 2003 - 02:03 AM
Posted 20 September 2003 - 02:31 AM
Posted 20 September 2003 - 02:35 AM
BTW: Crimson, can you see my pic in my sig.
Posted 20 September 2003 - 02:38 AM
does anyone use any COM port but 1 with their FA-123?
Posted 20 September 2003 - 02:43 AM
Regarding the COM port, i tried using the other ports in the past (COM 2, COM 3) however, in the end only COM 1 allowed me to transmit and receive programs.
Posted 20 September 2003 - 03:29 AM
That's wrong (even if it's written in Casio's manuel).Remember that you need to connect the calculator, turn on the calc. and later the PC.
You should verify your bios settings and check for IRQ conflicts.
#25 Guest_Bytefish Productions_*
Posted 20 September 2003 - 10:09 AM
Please write back if it's working now.
It should help users with the same problem.
Bye.
#26
Posted 20 September 2003 - 10:15 AM
not working..
it's the configuration in the Deive manger
"This device cannot start. (Code 10)
Click Troubleshoot to start the troubleshooter for this device."
The resource setting : " The device isn't using any resource cause it has a problem"
i think it' my pc...
let me try it on my sister's pc
damn, acutally no.. it's the cord
Hey Frozen! Please do not double post! Read the rules (topmost in main forum)! If you want to say sth. else
immediately after you said sth. please edit your post! Don't Spam the forum! I connected your posts. huhn_m
#27
Posted 20 September 2003 - 11:47 AM
#28
Posted 20 September 2003 - 02:37 PM
#29
Posted 20 September 2003 - 02:54 PM
#30
Posted 20 September 2003 - 11:02 PM
thanks guys .. for helping..
i guess the link cable is damaged..
#31
Posted 20 September 2003 - 11:04 PM
#32
Posted 20 September 2003 - 11:05 PM
have you ever been able to transfer files or is the first time? if its a new cable you should be able to return it.
#33
Posted 21 September 2003 - 01:19 AM
i tried it before .. it's like 2 years ago..lol
#34
Posted 21 September 2003 - 01:40 AM
That's wrong (even if it's written in Casio's manual).
You're right 2070, sorry by my mistake ( i thought one thing and wrote other
