-i got an algebra fx 2.0 and i downloaded the Casio Add-in installer because i wanted some cool add-ins i saw like put my calc. working with portuguese language!the problem is that i have the cable connected and it works fine with FA-123 but with the Casio add-in it?s always saying communication error!!i don?t get it!!why?s that??it works fine with FA-123 so it?s not from the cable or something!!can someone help??
-2nd-i need to pass some huge text to my calculator and i found a program to convert .txt files into .cat but my issue here is that in that text i need to use greek characters.well the program converts the txt all the same but in the calculator those characters just don?t show up!!i needed this so bad so if any of you guys know a way around this help me please!!!!!!!!thanks in advance!!!!
![:)](/dot/public/style_emoticons/default/smile.png)
P.S.->CrimsonCasio i went to your site but when i choose programs or games it shows me an 404 error page!!is it down?cool site there m8!!!
![:rock:](/dot/public/style_emoticons/default/rock.gif)
P.S2->sorry if the english is bad it?s not my native language!!!
![:D](/dot/public/style_emoticons/default/biggrin.png)
