Help convice a TI user...
Posted 05 November 2003 - 04:47 AM
Posted 05 November 2003 - 06:45 AM
Personally i like the bigger display and the friendly interface, icons, menus etc... Also i had heard that the classpad its the faster of all the 3D graphics calculators. Other thing, i hope that one day i could make and use 8086 ASM add-ins like with the AFX (i hope this will be possible).
(I hope my english will be understandable, if no i will edit this hours later)
Posted 05 November 2003 - 12:53 PM
The ClassPad does have it's charm. Perhaps if we knew what your friend is going to be doing with the calculator...
Posted 05 November 2003 - 07:22 PM
Posted 05 November 2003 - 07:30 PM
Posted 05 November 2003 - 07:32 PM
Posted 05 November 2003 - 08:19 PM
btw: this is qwerty were talking about right?
Posted 05 November 2003 - 10:16 PM
yea
Posted 10 November 2003 - 12:14 AM
It's impossible to persuade a TI user to buy a Casio...it's simply science-fiction!
Right now, with the new icon software they are extremely opposed to any casio's discussion!
Really It's an already lost battle!
See u
Posted 10 November 2003 - 01:44 AM
Posted 10 November 2003 - 02:38 AM
ha, he is going to get one
Posted 10 November 2003 - 03:57 AM
Posted 10 November 2003 - 04:40 AM
Posted 10 November 2003 - 03:04 PM
I see the two calculators as complementing each other. If I thought the TI-89 is best, there'd be no need to even look around for buying a ClassPad. But that doesn't mean I expect the ClassPad to be best.
I've already read most of the manual and used the simulator enought to know what I'm getting. So, the only comparison for me should be focused on the things that are common to the two. Which one is 'better', i.e., faster, more accurate, easier to use for a particular task?
I'll agree that the ClassPad seems to have a lot more built-in functions. Many of them can be implemented as user functions in the TI-89 so I can't take sides yet until I've used the ClassPad for a while. I was impressed by the 'simplify' example on page 2-7-3 of the manual. I tried to get the TI-89 to do this but failed.
It also has a very easy to use user interface (especially for applications like 'geometry' which would be rather difficult to implement using standard keyboard). A richer real keyboard, on the other hand, adds speed for more common calculations and once you've used it enough it becomes second nature.
I can't say I'm 100% satisfied with the ClassPad's real keyboard. It seems to be there for show-off not work. In such a limited keyboard, I'd expect it to be better thought out what goes on it and what doesn't. For example, the use of (-) is pointless because its function can be done with minus sign and the key could have been used for ANS which is rather useful. It could even be a SHIFT key that would double the number of real key functions. One might argue that the idea with the ClassPad is to use the touchscreen as much as possible. I'll agree to that but then I'll have to ask why not then make the screen all the way to the bottom of the device, have only an ON/OFF real button and have the soft keyboard (which is richer than real keyboard) take up the space on extended touchscreen where the real keyboard is now.
Anyway, to me it's more important how quickly (number of taps, clicks, or keystrokes) one can get to what his wants, and that has a lot to do with overall organization. And I think it's pretty good at that.
That's all for now. I'm still paying with it
tonyp AT acm.org
Posted 13 November 2003 - 02:53 AM
Posted 13 November 2003 - 04:22 AM
Posted 14 November 2003 - 02:21 AM
Posted 14 November 2003 - 02:22 AM
Posted 14 November 2003 - 03:36 AM
anyway, a few things about posting you should know: (its not a big deal for nw members but you should get in the habit)
1) stay relevent to the topic
2) if you think of something new, and its not been 5 minutes since your last post then edit your last post (unless someone else has posted in that topic, then its up to you)
3) dont leave obsucure/meaingless posts arround like clipings from James Joyces notebook.
4) Dont Spam
5) Read old post to make sure your question hasnt been answered (just a quick search is required, we do expect you to search through the archives (besides it makes us look smart))
ok, I'm done with the boring admin lecture...( :motz: )
