Units - converter for ClassPad
Ivaylo
, Nov 09 2003 11:38 AM
9 replies to this topic
Posted 09 November 2003 - 11:38 AM
Hello,
I has small units converter for ClassPad written who interest has can it under:
My Webpage
under "Links" as the first Download find.
or directly:
Converter
I hopes that it you becomes useful.
PP: Guidance unfortunately only on German.
For the translation I used "Google"
My Webpage
or directly:
Converter
Posted 09 November 2003 - 11:53 AM
You can test this
(it's the version 2.01f for the classpad)
it's in french but all units are in symbols
(for the decimal conversions (m-km) i hope you can do it without calc )
Posted 09 November 2003 - 12:17 PM
I already tested it 2 months ago ago. Is too slow (is please not bad).
With my things are altogether over 180 units.
Temperatur(?C, K, ?F, ?R, ?Re) and blood sugar (HbA1c) additionally.
Unfortunately it is pedantic a little.
I had the idea the program from the Main-window to start.
Assistance points it someone whether that is possible????
Posted 09 November 2003 - 12:38 PM
what does 'pedantic' mean ?
Posted 09 November 2003 - 01:06 PM
Deutsch:
Umstondlich ist meine Programm nicht Deine.
Ich hotte folgende Ideen:
ich schreibe ein Programm, die nur mit zwei Parametet die Einheiten umrechnen kann.
Ich hatte es gehoft, dass ich das spoter im "Main" starten kann.
z. B.: mit befehl convert(2,m-km) und dann EXE' />
English:
My program it's with minor difficulty to use, not yours.('pedantic' )
I would have the following ideas:
I write a program, which can convert the units only with two Parametet.
I had it go often that I can start later in the "Main".
e.g.: with instruction "convert(2, m-km)" and then [ EXE ]
English:
Posted 09 November 2003 - 05:14 PM
if you want to be able to run something from the main its best to put it in the library folder.
Posted 11 November 2003 - 11:21 AM
It is unfortunate that none of these converstion programs can be integrated into the operating system yet. As bulky as it is, my TI 92 Plus is still my main calculator at work, mostly because of this.
Posted 11 November 2003 - 11:25 AM
we only cant for now... eventually we will be able to make add-ins.
Posted 11 November 2003 - 04:35 PM
I hope it "CrimsonCasio" - I hope it!!!
Posted 11 November 2003 - 08:14 PM
dont worry, I know we will. I cant go further than that but be sure that we will have casio's support on this one.
