I guess I fuxored my connection to the calc. Maybe the setttings of the port are wrong.
So what com-port settings (baudrate, number of bits, protokol...) do you use in combination with the Casio Algebra FX2.0?
thanx
Serial Port settings
Misel
, Oct 21 2002 09:20 PM
Posted 21 October 2002 - 09:20 PM
Posted 21 October 2002 - 09:39 PM
just checked on another PC.
Is it possible to change some settings so that the Calc can't receive/send anything anymore?
Posted 22 October 2002 - 07:30 AM
You can't change any settings inside the calculator. Be sure to press the cabel to the bottom, you will hear an click sound. (I realy hope you know this). And for the settings I use standard. I just change the com-port so I use the active one. Becuse I have disabled one.
