classpad 300 was too dark
Nurhidayat
, May 31 2004 09:54 AM
9 replies to this topic
Posted 31 May 2004 - 09:54 AM
Posted 31 May 2004 - 04:43 PM
Hi!
I agree! At the beginning I was quite
with the LCD brightness, but now i've gotten used to it.
Probably the LCD has no backlight, because it would use up too much of the batteries.
Posted 01 June 2004 - 01:18 AM
Posted 02 June 2004 - 10:37 PM
that's kinda cool
Guest_siavash_*
Posted 16 June 2005 - 08:04 PM
probably there is a way to design a usb led light feed in classpad usb port
I'm intrested in designing it
Posted 16 June 2005 - 08:16 PM
You can also try changing the screen protector. The one which comes with the classpad makes the brightness even worse, as well as acting like a mirror! If you get a screen protector for PDA's the brightness will be much better.
[it will be hard to get a screen protector made especially for the classpad - not from casio that is. Just get a bigger one, any brand, not too cheap though
and cut it to fit.]
I complained about the brightness of the classpad before. After I installed a different screen protector, the brightness is just fine!
Posted 16 June 2005 - 08:30 PM
I've completely removed my protector because of the contrast problems.
I don't use my calculator that much though, so for those that use it all the time, you would probably want some form of protector over it to keep from scratching the screen.
Posted 16 June 2005 - 11:00 PM
i had the screen protector on mine for about a week then took it off. a few days later, i dropped it on the gravel driveway at my house, the cover popped off and my cp landed screen down in the gravel
but it only put a couple small scratches in it
Posted 17 June 2005 - 09:29 PM
As I know classpad USB port is a client port. this means you can't use it as a voltage source!! It would be nice if I could connect my usb flash drive into my CP
Posted 20 June 2005 - 12:32 PM
Unfortunately, there are only few PALMTOPS who have USB SERVER port. So this is not strange. However, the ClassPad has to be the first of its kind, yes? See you!
