X+EXP+On/Off and Y+EXP+On/Off
Posted 01 June 2004 - 01:10 AM
In OS 1.24 X+EXP+On/Off displays a menu with 3 options. What are these?
If you choice 2th optiion, you will see Calculator application PV! with address book application background!!!!!!!!!!!
With one tap on this cal, LCD sceens become dark!!!!
How can you explain these?
Posted 01 June 2004 - 04:38 AM
Posted 03 June 2004 - 01:49 PM
Posted 03 June 2004 - 03:32 PM
Posted 04 June 2004 - 07:19 AM
Posted 04 June 2004 - 04:39 PM
Posted 04 June 2004 - 05:43 PM
Posted 04 June 2004 - 05:58 PM
Posted 04 June 2004 - 06:29 PM
Posted 06 June 2004 - 04:48 PM
Hi guys.Y+EXP+On/Off enters to debug mode. WHat is differences between debug and normal mode.
In my CP dont happen nothing al presion this keys
Posted 06 June 2004 - 05:09 PM
Posted 06 June 2004 - 08:56 PM
Thanks for all.
Posted 06 June 2004 - 09:58 PM
be very carefull with the menus as you could really mess up your CP.
Posted 07 June 2004 - 12:39 AM
He said that him classpad was messed up, he entered to one of this menu's and choose some things, then him classpad dont turn on. I put on my site a warning about this
Posted 08 June 2004 - 12:29 AM
For my luck, tape-worm guarantee and they changed my calculator into other one
Posted 12 June 2004 - 08:35 PM
I think i figured out why you have to have the os v1.24 to run the spreadsheet application--the versions before that didn't have the spreadsheet dialogs.
Posted 12 June 2004 - 08:42 PM
Posted 13 June 2004 - 05:17 AM
Posted 15 June 2004 - 02:54 AM
Guest_Guest_Kilburn_*_*
Posted 10 March 2005 - 10:24 AM
I did it and the ROM has been erased!!!!!!!!
The system has been erased too!!! Now I can't use my ClassPad because when I turn it on it displays me FATAL EXCEPTION ERROR and restarts.
You were right Crimson!be very carefull with the menus as you could really mess up your CP.
Posted 10 March 2005 - 02:17 PM
describe what happens when you turn the classpad on. can you get back into the menu? can you configure the keyboard, etc.
Posted 10 March 2005 - 03:47 PM
unfortuantely...
I can align the screen, set the language, but when I configure the keyboard the ClassPad displays FATAL EXEPTION ERROR and restarts
So I can't get back into the menu
Posted 10 March 2005 - 09:15 PM
Posted 11 March 2005 - 09:20 AM
ok, when you get to the configure keyboard screen turn the classpad off and enter the secret menu and use it to reset your calc, then see if it will work (reset everything)
I tryed it in when I align the screen but not on the configure keyboard screen.
I returned it to the store so that they repair it.
I hope that I'll get it back soon!
#25
Posted 11 March 2005 - 09:16 PM
#26
Posted 11 March 2005 - 09:46 PM
#27
Posted 12 March 2005 - 09:03 PM
#28
Posted 12 March 2005 - 09:24 PM
#29
Guest_Guest_mkanter_*_*
Posted 22 March 2005 - 08:10 AM
I discovered that the usb wake-up is enabled. Thats how I did it. After aligning the screen (some other screen - not the error message - will show) i've plugged in the usb cable and the communication screen showd up.
Then i've made an os update (the 1.24 w/ spreadsheet version) and it worked.
And, In the hidden menus there are some functions, were you can show all the entrys in the folder list (so sdk or my side), but DON'T OPEN THESE FOLDERS!!! the classpad will crash.
