Hello
Firstly thank you for those that answer to my restlessness.
I am student of civil engineering and I need a calculator that adapts to this career, I dont know if the classpad or the texas voyage, adapt better to my career, but not only with the functions that possess and with the programming capacity. For this reason sends them the following questions:
1. The differences in programming of these calculators
2. Which are the applications that it can be installed to the classpad
3. The classpad is good for civil engineering in programming
4. Has the classpad programs for civil engineering as the texas voyage has it
5. That calculator should buy
I have almost read a lot the whole forum and myself call the attention the questions of @ tec1, since I imagine that @ tec1 follows civil engineering, and it has thrown three questions that are key for civil engineering, and regrettably the classpad has not approved them, Maybe @ tec1 desilucionado should be a little.
Greetings colleague @ tec1.
P.D. Love to the calculating casio
Pardon for my English
En Espanol
Hola
Primeramente muchas gracias por los que contesten a mis inquietudes.
Soy de estudiante de ingenieria civil y necesito una calculadora que se adapte a esta carrera, no se si la classpad o la texas voyage , se adapten mejor a mi carrera, pero no solamente con las funciones que posean sino con la capacidad de programaci?n. Por esto les envio las siguientes preguntas:
1. Las diferencias en programaci?n de estas calculadoras
2. Cuales son las aplicaciones que se le puede instalar a la classpad
3. La classpad sirve para ingenieria civil en programaci?n
4. Tiene la classpad programas para ingenieria civil como la texas voyage lo tiene
5. Que calculadora debo comprar
He leido casi todo el foro y me llamar?n mucho la atenci?n las preguntas de @tec1, puesto que me imagino que @tec1 sigue ingenieria civil, y ha lanzado tres preguntas que son claves para ingenieria civil, y lamentablemente la classpad no las ha aprobado, talvez @tec1 debe de estar un poco desilucionado.
Saludos colega @tec1.
P.D. Amo a las calculadoras casio, y casi se me olvida lean las diferencias entre la claspad y la ti en este foro le dan con todo a la classpad, entre lo m?s importante que le dicen es que es una claculadora simplona en programaci?n
Help
diego
, Aug 06 2004 09:36 PM
Posted 06 August 2004 - 09:36 PM
Posted 06 August 2004 - 09:49 PM
ClassPad is a new tool and doesn't have resources as much as TI Voyage. CP basic is a bit slow but I like it more. If ClassPad SDK would release you can write and develop your application or if you aren't a programmer you can find some applications or basic programs that they are related ti CIVIL engineering. I suggest you that try them both
(Classpad Manager and TI Emulator). You will find which is suitable for you.
Posted 07 August 2004 - 02:40 AM
Hola Diego.
1. Principally (i dont know TI), you can use the stylus in the programs, sometimes is much better than only with the keyboard. I dont know wich calculator's programation mode is fasters.
2. All the add-ins availables for the classpad are in www.casiocalc.org, and some of the most important programs on BASIC.
3. Yes, both calculators must do similar programs, all depend of the programmator
4. No
5. The one you think is the better.
1. Principalmente (no conozco calculadoras TI), tu puedes usar el lapiz optico en los programas, muchas veces es mas rapido y mejor que usando solo el teclado. No conozco cual modo de programaci?n sea m?s r?pido de ambas calculadoras.
2. Hasta el momento, todo lo disponible (add-ins, programas para la flashrom) estan disponibles en www.casiocalc.org, as? como los programas mas importantes en BASIC.
3. Si, no tienen ambas dificultades para hacer programas para ello, todo depende del usuario
4. No
5. La que creas mas conveniente a tus gustos.
De donde eres Diego?
4. No
4. No
Posted 07 August 2004 - 06:37 AM
English (translation with Babel Fish)
Casio completely is overturned in the development of this new technology, with great equio behind, is commanded by the inventor of the graphical computer. Clear that it has limitations but, which I can say to you is that they are working in it and, according to it is improved, allow you to go to ?adiendo software. Soon it leaves the version 2.0 that, at didactic level, improves the benefits considerably. Only an example, has an option that allows to be developing problem you step by step (it is to you saying in each step if it is or or badly), improves the geometry program and increases the benefits in programming. At the moment that this methodology follows "creciendo" their benefits are limitless, without forgetting to us the emulator, that are impressive and it allows you to work with the computer, etc.
Espa?ol
Casio est? completamente volcado en el desarrollo de esta nueva tecnolog?a, con un gran equio detr?s, capitaneado por el inventor de la calculadora gr?fica. Claro que tiene limitaciones pero, lo que te puedo decir es que est?n trabajando en ello y, seg?n se va mejorando, te permiten ir al??adiendo el software. Dentro de poco sale la version 2.0 que, a nivel did?ctico, mejora considerablemente las prestaciones. S?lo un ejemplo, tiene una opci?n que te permite ir desarrollando problema paso a paso (te va diciendo en cada paso si est? bien o mal), mejora el programa de geometr?a y aumenta las prestaciones en programaci?n. En el momento que esta metodolog?a siga "creciendo" sus prestaciones son ilimitadas, sin olvidarnos del emulador, que es impresionante y te permite trabajar con el ordenador, etc.
Seguimos intentando vuestras visitas en nuestro foro en espa?ol...
Un saludo
Espa?ol
Un saludo
Posted 08 August 2004 - 04:29 PM
Hola a todos
Gracias por sus respuestas
soy de Ecuador.
Espero muy pronto comprarme la Classpad, y espero que no me desepcione
sobre todo en programaci?n
English translation:
Hi all you.
Thanks by replying
I'm from Ecuador
I hope i will buy my classpad soon, and i hope it will not dissapoint me
specially in programming features.
soy de Ecuador.
Hi all you.
Thanks by replying
I'm from Ecuador
Edited by betoe, 08 August 2004 - 05:59 PM.
