You can now use it to create sprites in 5 colors, and get the code needed by gxLib to display it. There is also a new "conversion wizard" to convert RGB images into 3 or 5 colors
There are still 2 things to do:
- The <{GNULINUX}> version: it works fine for now, I just have to change a couple of thing i've made on the windows version (and that I forgot on <{GNULINUX}>
- The translation kit: anyone will be able to create a new translation file for the software (the 2 current languages are English and French). I will just give you the 'Qt linguist' software, with a little explanation on it
As usual, comments are welcome
You can find the soft on the File Sharing, or directly here.
(And thanks again to Crimson who gave me help for the english tranlation of the docs
