Huh
What they offer is an USB linkage cable for casio FX/CFX/AFX Graphic calculators, but you can 't use it for add - ins I think.
Btw., 50? is a dear price for it, but not that expensive Casio FA-123 software was a few days ago
Posted 29 December 2004 - 01:26 PM
Posted 29 December 2004 - 08:39 PM
Posted 30 December 2004 - 08:19 AM
Posted 30 December 2004 - 10:13 AM
Posted 30 December 2004 - 11:37 AM
Posted 30 December 2004 - 05:42 PM
Posted 07 January 2005 - 02:47 PM
Posted 07 January 2005 - 03:40 PM
if you know something about electronics, make your own using integrated chip FT232BM from FTDI, it's the most-expensive part of such solution and you can get it for abou 8$ (here, in cz) - whole construcion will be about 10$ and you will have same abilities with it, because FTDI provide drivers for it (Win, <{GNULINUX}> too) which can emulate COM, so Flash100 (with glink of course) and FA-123 will work fine...You're right, I found another webpage now were they offer an USB <--> COM adapter with a special driver that "works with virtually all software that uses an RS-232 serial port" (thus emulates it). Didn't know that this was possible at all.
So it really should work with FA-123 / Flash100, too (and this for cheaper than FX Linkkit is; btw maybe the Linkkit doesn't provide it's drivers to other windows software?)
Think I'll buy one(cause my Laptop also has no COM anymore)
Posted 08 January 2005 - 06:28 PM
Posted 08 January 2005 - 09:32 PM
Posted 09 January 2005 - 05:47 AM
Posted 09 January 2005 - 02:34 PM
i think, problem, which can occure during using "generic" USB2COM, is when the control software of the device uses COM's special signals, like RTS (ready to send) or DTR (data-terminal ready) eg. as a voltage supply for levels-converting IC or break-bit abilities... it seems that not all the cables can handle it correctly. who is skilled, have a look at FT232 features http://www.ftdichip....cts/FT232BM.htmOne problem you might run into with a "generic" USB to serial adapter is it might not work with all devices.
Posted 17 January 2005 - 08:16 AM
HI again, sorry I make so many postings.Sorry for replying to wrong thing.
As mentioned about, I a calculator - USB cable link (which actualy came with my personal organizer). I want to use the same calbe for the calculator. Hower, I dunno how to make it work. Under FA-123 Communications I selected Com 4, where the cable is..but it doesn't work. The only driver I installed was from the personal organizer software.
Btw, i dunno much about this stuff. I don't even know what a driver is or does, all i know is that I need to install one whenver i put in new hardware. So if someone can expalin, it would be gladly appreciated.
Also, Where do I get this driver that allows the USB port to act like a com port? Can someone post a link to it where I can download it.
Thank YOu
Sorry for replying to wrong thing.You're right, I found another webpage now were they offer an USB <--> COM adapter with a special driver that "works with virtually all software that uses an RS-232 serial port" (thus emulates it). Didn't know that this was possible at all.
Edited by Andy.Davies, 17 January 2005 - 09:27 AM.
Posted 17 January 2005 - 09:39 AM
Posted 17 January 2005 - 10:15 AM
Wow, thank you so much..you guys are quick.if you have driver emulating COM port, it should be OK; error message that port is already in use can be caused (and i think so) by always-running app that monitors the device at the end of your cable and when the organizer is detected, it launchs the control sw. try to find and end this process and then try to use COM4 (eg. open in hyperterminal) or post a list of running processes and i will tell you which one it is (if exists).
Posted 17 January 2005 - 12:12 PM
hmm, it seems no of those processes belong to such sw, try to open the port (sure that its COM4? - look in devmgmt.msc) in hypertrm.exe and tell the resultWow, thank you so much..you guys are quick.
Ok, so far, as I understand, as long as I have driver emulating com port..it doesn't matter where the driver is from. Thus, even if its from the Organizer it can still be used for other stuff?
I already shut off the software that the organizer uses.
Still says, "failed to open port."
sorry, didn't know how to register
Posted 18 January 2005 - 12:05 AM
Posted 18 January 2005 - 12:28 AM
Posted 18 January 2005 - 12:42 AM
Posted 18 January 2005 - 02:19 AM
Posted 18 January 2005 - 05:50 AM
Posted 18 January 2005 - 01:42 PM
In this way DOS sux, cause it has to be emulated
The ntvdm.exe is a invention of Micro$oft and is a HUGE memory consuming process ensuring 16-Bit compatibility.
I would say Windows sucks
Posted 18 January 2005 - 10:38 PM
winNT doesn't run on DOS 7.0
Posted 19 January 2005 - 02:51 AM
Posted 19 January 2005 - 03:07 AM
Posted 20 January 2005 - 04:38 AM
Posted 20 January 2005 - 06:47 AM
Posted 28 January 2005 - 01:50 PM
Posted 28 January 2005 - 03:51 PM
Posted 13 March 2005 - 06:32 PM
Posted 29 June 2006 - 08:51 AM
Posted 29 June 2006 - 11:46 AM
hey i have a fx-9860G AU calc and ive lost the cd i got which has got the driver on so i cant connect it to my comp. do u guys hav ne idea where i could get a copy? free if possible
thanks
Posted 16 June 2008 - 03:14 PM
Does anybody know where can I find the electronic diagrams to make my own rs-232 cable for the calculator?
Posted 18 June 2008 - 03:51 PM
And did someone found the USB schematic? I would like to make the two.
Posted 18 June 2008 - 09:37 PM
