Somone Help Me, Please!
Posted 21 March 2005 - 01:29 AM
I already downloaded the Add-In Installer some place else, but when I try to install add-ins, It just freezes in the conecting to the classpad window, and it won't do a damn thing to connect, I don't know if it's because I'm not registered, or because I don't have the OS, or any other reason I just don't know... If someone would please help me, I'd really appreciate it!
Enrique.-
Posted 21 March 2005 - 01:39 AM
Posted 21 March 2005 - 01:46 AM
Don?t worry just write the numbers in the back of the class pad but don?t write them all just one part of them I don?t remember which part but there is only two of them I thing it is only the first part and good lucky
THANXS A LOT, THANX U!!! I WILL NEVER THANX U ENOUGH!!!!
Guest_Guest_*
Posted 21 March 2005 - 02:31 AM
Enrique.-
Posted 21 March 2005 - 08:44 AM
Posted 21 March 2005 - 07:11 PM
is your classpad in the correct mode? when your linking it to your computer make sure you select the Install OS option, it defaults to the CP Manager settings which do not work when installing an Add-in or OS.
Enrique.-
Posted 21 March 2005 - 07:25 PM
Posted 21 March 2005 - 07:35 PM
while (it doesn't work) { retry(); }
Posted 21 March 2005 - 07:58 PM
well, first off, when the classpad "wakes up" you will have to hit clear to exit out of the link mode it is in and manually select install add-in... i dont know what this CESG502 is, but see if placing the add-in/OS installer in the same folder as your CP Manger works.
n animate image of the CP hat says to select comunication in my CP and then hit the 1st icon, I think it's transfer, I do so, and nothing happens, no file is saved in my computer, and I honestly don't know what to do, because everytime I select something in my classpad when it's connected to my PC, in my PC appears a message of a new hardware found, under the name of CESG502, like when you conect a scanner for the 1st time, and it says that a new hardware was found, and that you need to install something to make it work, well, that's the same with me, I don't know what I'm doing wrong, 1st, I couldn't register my CP because there were too many numbers on the back of it, and I didn't know I had to type the 1st half, I did it, I couldn't download the OS because I wasn't registered, I finally registered it, now I can't do a damn thing with it, I'm honestly freaking out, I'm about to throw my CP against the wall, honestly, it's too much of a protocol if you ask me, lol
Enrique.-
Posted 21 March 2005 - 08:00 PM
i've had the CESG502 problem... but i don't know who i got it fixed, just :
How so?... what's that of while (It doesn't work) { retry(); }
Posted 21 March 2005 - 08:09 PM
Posted 21 March 2005 - 08:12 PM
i'll let casio know of your problem, they'll probably have a solution. in the mean time what windows version are you using?
thanxs a lot, I'm using windows XP
Posted 21 March 2005 - 08:13 PM
check back later
Posted 21 March 2005 - 08:15 PM
ok, e-mail sent... if they know a fix we should have it today or tomarrow
check back later
THANXS A LOT!!! REALLY!!!
Posted 22 March 2005 - 09:03 AM
The "ClassPad300_OS_ver0200_Update.exe" was developed and released by CASIO Tokyo. If the user is outside the US he should contact the support center or distributor who maintains Casio products in his region. If he lives in the US he can send his ClassPad to us. We can recover the ClassPad and
upgrade his OS to ver2.00.
i guess they dont have a direct fix, but there willing to do it for you... if i were you I'd send in your calc as a last resort (unless you know you wont be using it for a while). keep playing around with it and i'll enquire further to see if there is a quick fix.
Posted 22 March 2005 - 04:57 PM
Hmm, it could be a driver problem. You installed the Manager, right? The Manager should install the drivers for the ClassPad.because everytime I select something in my classpad when it's connected to my PC, in my PC appears a message of a new hardware found, under the name of CESG502, like when you conect a scanner for the 1st time, and it says that a new hardware was found, and that you need to install something to make it work, well,
I has a similar problem a long time ago (I think on Windows 2000) when I connected the ClassPad before installing the Manager. The computer got confused and tried to use the wrong driver. After that it was somehow stuck on the wrong driver, even after installing the Manager. I don't know if this is your problem or not.
Can you use the Manager to transfer a file?
Posted 22 March 2005 - 06:12 PM
did you tryied on another computer? Are you sure this is not your CP problem?/?
Posted 22 March 2005 - 11:34 PM
Enrique.-
Posted 23 March 2005 - 02:04 AM
Hmmm... I don't know, guess I could uninstall, and reinstall again, and see... as for if my CP is the problem, I don't know, I handle properly, and I can't transfer or recieve anything... when I run Add-in and try to connect it to my CP, it just doesn't connect, unfourntunately, I live outside the U.S, so, I guess I could go over a casio supplier and see what they've got to say to me as a last resort, but I'll keep on trying and tryin... CrimsomCasio, thanxs a lot, really! all of you, I'll try to do everything in my power, I'll keep you posted!
Ok, from this it sounds like it is the connection between your ClassPad and computer and probably has nothing to do with the OS installer. The things I can think of that could be causing the problem are...
1) Computer Operating System
Are you running anything lower than Windows 98 SE? Are you running in a virtual machine or over a Windows Terminal Server?
USB normally doesn't work in these environments.
2) PC Hardware (USB ports)
Try a different USB port. If you are using a HUB, plug the ClassPad directly into the USB port on your computer. If you have both USB 1 and USB 2, try both.
Can you connect any other USB device to this computer? See if you can first install the Manager and then connect your ClassPad on another computer.
3) ClassPad Drivers
Unplug your ClassPad and uninstall the Manager. Next do a search on your computer for all files matching the pattern CESG502*.* and delete these files. You will have to display hidden files and folders in Windows Explorer. The typical location for these files are...
C:\WINDOWS\inf
C:\WINDOWS\system32\drivers
Finally, reinstall the Manager and plug in your ClassPad.
4) ClassPad Hardware
Find a friend with a ClassPad and have them try theirs on your computer.
Posted 23 March 2005 - 11:36 PM
Guest_Guest_*
Posted 02 March 2006 - 03:46 AM
Posted 05 April 2006 - 11:02 AM
OK im a major newb and im trying to get games onto my ClassPad and i've got the Add-In Installer thing but my GODDAM classpad wont connect to the bloody thing, plz help me
Looks like I have the same problem as you. I have followed the instructions on the previous posts, but am still
So now when I plug in the C P to the computer any port, its just brings up the sound that something is connected e.g. like a camera, but you can't see it in the drives or no icon. When i try the manager it says it can't connect and the CP say error communicating. Add-inn program just freezes on connection.
Running XP home.
Any help would be of great assistance.
Posted 07 April 2006 - 04:19 PM
1) You don't want to use the Manager when installing add-in applications. You have to use the PC Add-in installer with it.
2) You can't use the automatic USB connection on the ClassPad to install add-ins. You have to use the Link|Install|Add In menu to start the Add-in installer on the ClassPad. If the automatic connection starts hit the Clear key to break the connection.
3) Make sure you don't have v2.2 of the Manager open in Exchange, it automatically tries to connect to any ClassPad that is connected via USB. If you open the Add-in installer on a ClassPad and Exchange v2.2 automatically tries to connect it will corrupt the connection protocol. You'll have to disconnect the cable, close Exchange, and try again.
I hope this helps. Good luck.
Posted 14 April 2006 - 08:22 PM
Do you have another computer you can try?
#25
Guest_Guest_*
Posted 07 February 2007 - 06:22 AM
To do this:
1. Right click 'My Computer', select Hardware from the tab, then select 'Device Manager'.
2. Find the section 'Unknown devices' or equivalent and open it.
3. Find the classpad in the menu.
4. Right click it and select 'Reinstall driver'.
It worked for me and I am running Windows XP sp2.
#26
Guest_bloooder_*
Posted 09 December 2007 - 01:56 PM
PS. Sorry, but i'm not good in english
#27
Posted 11 December 2007 - 02:47 PM
I have classpad, but i don't have CD with Classpad Manager. I think, but i'm not sure, that classpad manager v3 (30-day trial) is only an emulator, so i need classpad manager from CD(?). Where i can download it?
Look here --removed by moderator--
#28
Guest_Devil_*
Posted 14 December 2007 - 02:47 AM
Yes, it is in a 2.0 usb port, no it is not in a hub it's directly connected, yes i have cp manager, no i didnt plug it in be4 installing it.
Thx a lot if u could help me!!!
#29
Posted 15 December 2007 - 04:21 AM
Hope it helps
#30
Guest_Devil_*
Posted 15 December 2007 - 05:33 AM
#31
Posted 15 December 2007 - 08:09 PM
#32
Guest_Devil_*
Posted 20 December 2007 - 10:22 PM
#33
Posted 21 December 2007 - 02:20 AM
so ur not versing me in cs1.6?
i do play CS: Source and Fortress Forever
When you go to communications. tap setup, then "open setup menu" annd in cable type, you must select USB cable to PC-Calc communications and 3-pin cable to calc-calc communication.
#34
Guest_Devil_*
Posted 20 March 2008 - 06:45 AM
