Cp Flash Memory
Posted 13 July 2005 - 01:12 PM
Posted 13 July 2005 - 04:57 PM
There is also reserved space to save your MCS from RAM when you turn your ClassPad OFF. This takes 512K. This is what makes it possible for you to remove your batteries and later put new ones in and still have all your data.
I'm not sure what the other space is used for, but I expect there is at least some space set aside for future improvements in the OS.
Posted 21 September 2005 - 09:05 PM
I think it,s not impossible !
we will need more user storage in the future ,
for example my Eactivity user free storage finished 6 month ago !
Posted 21 September 2005 - 10:29 PM
it isn't possible because the ClassPad is not a USB server. It is a USB client. It doesn't provide any power for a USB drive.did you think about using a USB drive for Classpad ?
Posted 21 September 2005 - 10:51 PM
Posted 22 September 2005 - 03:31 PM
Posted 22 September 2005 - 04:27 PM
Yes, it's call a PC running the Manager.so you mean that there is no way to have extra storage capacity for classpad ?
Actually, their is no way to increase the memory of the ClassPad. Of course you could open it up and replace the RAM or Flash chips, but they are soldered in so I wouldn't advise it.
The ClassPad has two storage locations, MCS and Flash. MCS use RAM and is limited to 512K, and there is no way to expand this. This is where variables are stored. Flash is used to store the OS, for eActivities, and for Add-ins. It is also used to save MCS when the ClassPad is turned off, so if the batteries are removed it will remember all your data.
