I can?t transmit/receive data between FX1.0 and fx7400
When I try to transmit a program from fx 1.0 to fx-7400, I can?t, I only can transmit data using E-con -> Program converter and then I can transmit that program created by E-con, so the cable and the calcs are operating fine.
What I?m a doing wrong?
In the manuals these calcs have different baud-rates how can I change that?
I just want the symbol => , in FX1.0 that?s all !!!!
Transmit/receive Between Fx1.0 And Fx7400
rssantiago
, Sep 30 2005 05:43 PM
Posted 30 September 2005 - 05:43 PM
Posted 30 September 2005 - 06:01 PM
While in FX's data communication menu, try pressing F4' /> F5' /> F6' /> (in a row, not at once). As far as i know, this is a recive mode using fx7400 protocol.
At least it works like this with AFX2.0...
Posted 30 September 2005 - 08:53 PM
it also works with FX 1.0+
it is also compatible with CFX calcs.
