hello, i'm dirk and i have a question about program some games.
waht does this <> mean, if you just type that (by rel) , you get an syn error so my question is: what command is that and where can i find it?
thanks, dirk
help
dirk
, Feb 11 2003 02:32 PM
6 replies to this topic
Posted 11 February 2003 - 02:32 PM
Posted 11 February 2003 - 03:05 PM
Usually when people type out their BASIC games in text, the <> stands for the "not equal" sign. On the CFX-9850's, it located by pressing these buttons in this order: Shift - Vars - F6 - F3 - F2.
It will look like an equal sign with a slash through it. Hope this helps!
Posted 12 February 2003 - 03:55 PM
thanks!!!
do you know what the standardis for MAT? because my version of snake (by Nick Skaggs) isn't working...
Posted 12 February 2003 - 04:27 PM
If you mean the format of matrices in Casio:
example:
Mat A[R,C]
Where A is the name of the matrix A->Z + Ans
R = Row
C = Cullomn
example:
Mat A[R,C]
R = Row
C = Cullomn
Posted 12 February 2003 - 04:32 PM
hmm.. jes.. but you have to type: Fill (0,List1) but than you get the dim error...
Posted 12 February 2003 - 06:00 PM
You need to set the dimensions of a list before using it:
N->Dim List X
N=Number of entries in list
X=List number
If your copying a program somone else wrote, you have either skipped this line, or they have failed to initialize their list..
N->Dim List X
X=List number
Posted 12 February 2003 - 06:41 PM
if you set the list to 255 the game will not have any problems, but it will take up a lot of memory, I recomend setting it to about 10 then keep going one up untill it stops giving errors.
