1) Tell us the name of the program! Do you mean FA-124?
2) What extensions refuse to transfer? If you mean cat files & co. then read the tutorials on installing the 9850 cat files on the 9860.
1) Yes
2) All except g1r but the tutorial state its g1m so my com might be displaying it to short 0_o.
This was one of the only tutorials in which i was able to find
To convert fxi -> cat -> g1m
select type of calculator Graph 25/65 (7400/9850) in FA-124
create new 7400/9850 program, edit it
use cat2fxi to get stuff to paste from fxi into CAT 7400/9850 format
now Save As.. save cat file using Algebra FX series
close everything- - - - - - - - - - - - - - - - - - - - - -- - - - - - - - - -Not needed (already have the cat folder)
open cat file in FA-124 which is now Algebra FX format CAT- - - -My FA-124 wont even open Cat files (wont display it as if it doesnt exist)
edit it in FA-124, copy the program and change mode to Graph 85- - - -- - - - - 0_o
create new g85 program, edit it and paste stuff from Algebra fx CAT- - - -- - - Obviously i cannot continue
Save as g1m
There was another program above it describing a tutorial (found in tutorials section) Although to use it you have to back tarck the tutorial and obviously i am not smart at this stuff so.... you get the picture.
This is the assumption that the FA-124 can transfer (on my com anyway
) g1m files as the only extension i have succesfully transfered (to my knowledge) is .g1r
In short the tutorial on this site i am finding to confusing, can somebody rapidly dumb it down for me, find me another tutorial if i missed one, or head me in the direction of a good conversion programme.
The main list of programmes in which i want converted (mainly from casio avenue) incude .Cat , g1a (physium) , fxi, .cas, ctf (There the main culprets all in which The programme FA-124 cannot open or send to my calc.
If you still do not understnd what i am trying to say please give me your email address (or i give you mine) so i can show you a picture of what i mean or give you examples of the programmes i am trying to work with
If you read all of this you deserve to give your self an award
