Help With Linear Ecuations In Lua
Guest_Alberto_*
Posted 13 August 2006 - 12:50 PM
I wrote tis but don't work:
print (cas.solve({"5x-y=2","6x+y=15"},{x,y}))
also i tried with expresions (ex: f6=cas("...")
Please anyone can help me?
Thanks a lot
Alberto
Posted 13 August 2006 - 05:46 PM
print (cas.solve("{5x-y=2,6x+y=15},{x,y}"))Works by me.
Posted 14 August 2006 - 07:31 AM
You must quote the whole CAS expression, with or without the command solve, i.e.,Hi! I want to resolve a simple linear ecuations in lua, but how?
print(cas.solve("{5x-y=2,6x+y=15},{x,y}"))or, equivalently,print(cas("solve({5x-y=2,6x+y=15},{x,y})"))However, you should not use the above expressions: they give a CP list, {x=17/11.y=63/11}, which is just printed on the screen, nothing more than that. The list is not really useful, since it cannot be used in a CPLua program (it is a CPLua variable of the type "userdata"). However, you can get numerical values for x and y in CPLua as follows:
cas("solve({5x-y=2,6x+y=15},{x,y})=>aux")
x=cas("getRight(aux[1])")()
y=cas("getRight(aux[2])")()Here, the CP variable "aux" is used to store the list, then CAS functions are used to get the numerical values for x and y, which can be used in your CPLua program. If you have questions on how this code works, let me know.
Posted 15 August 2006 - 05:12 AM
equation but I have problems whit the manipulation of matrix en CPLua, I tried so many thing using just
CPLua or using the CAS but I have problems...
How can I do this in CPLua using the CAS and without it?
1 x [2,3,4]
sorry about the dumb question but I really have problems whit that...
Another question whit this code:
m={{4,-2,3},{3,2,6}}
mm=cas("m")
y=cas.elem(mm,1,1)
x=tonumber(cas.elem(mm,1,1))it prints this:
(a blank space) nil
Can I use the all the CAS functions of Matrix-calculation?
Thanks...
Posted 15 August 2006 - 07:51 AM
In a nutshell: You are trying to extensively mix CAS and Lua calculations. After developing several algorithms in CPLua, my personal conclusion is this: avoid CAS operations in CPLua programs as much as possible; it needs headache-programming, and I don't think that it is really needed. In most cases, it is better to use CPLua for-loops to perform matrix operations, instead of using the CAS. For example, to get a part of a matrix, use LNAutils' function Part (or write your own function for this); for matrix multiplication, use MatMul (also included in LNAutils). Calling the CAS to do similar operations needs to (1) convert a CPLua table to a CAS matrix, (2) perform the operation using CAS functions, (3) convert the result to CPLua form. This makes your program difficult to read and to debug. Of course, if you need symbolic computations, you can't avoid using the CAS within a CPLua program; however, the problems you have posted involve numerical (not symbolic) computations, so, in these cases, my opinion is that you should avoid the CAS completely.Can I use the all the CAS functions of Matrix-calculation?
Btw, the Gauss-Jordan method for solving linear systems is not used in practice, because it is slow, compared to more sophisticated methods. Gauss-Jordan is only used as an introductory method for educational purposes. If you just want to solve a linear system efficiently, use LU decomposition instead (it is included in LNA), or QR decomposition; both methods are much faster than Gauss-Jordan. Anyway, if you really need to write a CPLua program implementing the Gauss-Jordan method, you can easily do it without using the CAS at all.
Posted 15 August 2006 - 08:03 AM
m={{4,-2,3},{3,2,6}} <----mistake
mm=cas("m") <----- mistake
y=cas.elem(mm,1,1) <----must be converted to nuber as below
x=tonumber(cas.elem(mm,1,1))Proper code for this operation:
m="[[4,-2,3],[3,2,6]]" mm=cas(m) x=tonumber(cas.elem(mm,1,1))
If want to use 'Y' in Lua calculations, must be converted to number, same as 'X'.
Posted 15 August 2006 - 08:19 AM
Are you sure that your code is correct? I think it's not: x=tonumber(cas.elem(mm,1,1)) is incorrect. To convert the result to a CPLua number, useProper code for this operation:
x=cas.elem(mm,1,1)()instead.
Posted 15 August 2006 - 08:42 AM
Posted 17 August 2006 - 04:47 AM
only Lua functions
Guest_Alberto_*
Posted 17 August 2006 - 09:57 PM
Posted 19 August 2006 - 05:20 AM
the firts row of the matrix you have a zero because in that case it does not work
I'll add it tomorrow...
Posted 19 August 2006 - 07:46 AM
Posted 19 August 2006 - 07:55 AM
To tell you the true you are like the programation and Numerical Analysis teacher that I've never had...
Posted 20 August 2006 - 02:20 AM
Gauss-Jordan
