I have Heat Transfer Course on this term.
Does anybody have any related App. or eActity?
Specialy some for Numerical Solution method or Finite Element method?
Heat Transfer
Behnoud
, Nov 14 2006 07:23 PM
Posted 14 November 2006 - 07:23 PM
Posted 15 November 2006 - 12:21 AM
Did you mean.. finite diference method?. Finite element analysis is a lot more complex dude
btw, is really easy to program it using Lua, only you will need LNA to solve the linear systems
Posted 17 November 2006 - 05:01 AM
Yes, I just wanted to example some method.
Have you worked on it?
Posted 17 November 2006 - 10:54 AM
You can use my physic addin.
Posted 17 November 2006 - 11:55 PM
Dude... WTH are you thinking!... It's heat transfer!!!!!. not ball throwing
really you know about heat transfer???
@behnoud: No, i did'nt
