Hello,
I've had my Classpad 300 for about 2 years now.. been working great in that time
but I don't know what's going on with it right now
I was using it the other day and It suddenly stops recieving input from either the keypad
or the touchscreen. its wierd.
for instance.. i turn it on. and I'm using the touch screen, using the soft keyboard.
and if I press the keypad. the cursor stops blinking and the calculator crashes until
i touch the screen again.. sometimes is the other way. Im using the keypad. and when
I try to use the touch screen it doesn't read any input until I turn it on and off
i have already reset the RAM, initialize and installed the latest bios and still giving me trouble
I was wondering if anyone else got the same problem.
Thank you for your time.
Problem With My Class Pad (help!)
Static
, Jul 24 2007 08:04 AM
9 replies to this topic
Posted 24 July 2007 - 08:04 AM
Posted 24 July 2007 - 12:50 PM
What did you do with it before It suddenly stops recieving input from either the keypad or the touchscreen?
Posted 24 July 2007 - 06:14 PM
nothing wierd.. didn't drop it or had any fisical strain to it..
Guest_sERGEOFF_*
Posted 27 August 2007 - 08:28 AM
Hi ...
Did you solve your problem with your classpad ?!!!
becouse i have the same trouble with my class pad until yesterday all fine with os3.02 but this morning the keyboard doesn't work good !!!
the on/off button worky only some time !!!!
what can i do to solve this !!!!
Cmp.
Cmp.
Posted 28 August 2007 - 01:20 AM
It might be better PM-ing the guy. Sometimes, if he has it enabled, if you send him a PM a email notification is sent to him about a PM, which may get you a response from him.
Guest_Sergeoff_*
Posted 28 August 2007 - 09:53 AM
Thks !!!!
I will send a PM to him ....
Posted 28 August 2007 - 02:57 PM
Make sure though that you register and sign up for a account here at the UCF. The only way to PM someone is to be registered first.
Posted 04 September 2007 - 02:09 PM
nope.. my classpad is still malfunctioning..
Posted 10 September 2007 - 09:17 AM
I think a photo should be useful.
And the best way is sending it to casio support.
Posted 20 September 2007 - 10:05 PM
i gave up.. it seams to have an electric problem.. i noticed it drains new batteries in just a couple of hours. i just bought a CP330.
thx anyway
thx anyway
