les pido ayuda con un problema que tengo
la calculadora enciende pero la pantalla tactil no funciona, inicia normalmente y visualizo los datos pero no puedo operar la tactil
la ves anterior que empeso a pazar esto alcance a reset la calculadora por "system" => reset pues la tactil medio funcionaba y despues empeso a funcionar bien, pero la deje de trabajar un tiempo y ya no funciona para nada,
la classpad tiene OS 3.01
como puedo reset por teclado o que puedo hacer
les agradesco compa?eros casio por su ayuda.
disculpen que no escriba en ingles.
Translation:
Hi classpad partners
I need some help. The classpad turns on but the touch screen isn't working.
First it start failing and i did a reset because the touch screen was having problems, but it was possible to use it. I can see the data on the screen but the touch screen is not working, but after the reset it worked ok again. From some time i didn't used the classpad and now the touch screen is not working again. I think its a system error that isnt detecting the screen or something like that, please help me with this problem, i need to use it urgently. I have installed OS 3.01.
How i can do a reset using the keyboard?
Thanks by your help.
Edited by betoe, 06 October 2007 - 04:28 AM.
Translation added
