Problem With Matrix. (help)
Posted 24 October 2007 - 01:54 AM
(To resolve newtom-raphson)
In LUA9E running the code in CPLUA.EXE
The results are correct but CPLua.cpa are incorrect ...
My OS is V3.02
Tengo un problema con Cplua0.9E no me entrega los resultados correctos de la matriz
y el CPlua.exe la aplicacion para windows si me da los resultadfos correctos
The code
require("cas")
F=input("ingrese la funcion")
f1=cas(F)
a=input("x0=")
ite=input("numero de Iteraciones")
d=cas.diff(F,"x")
f2=cas(d)
MZ={}
for n=2,ite do
MZ[n]={}
MZ=a
MZ[n]=MZ[n-1]-f1(MZ[n-1])/f2(MZ[n-1])
print(MZ[n-1])
end
Dowload cade
http://www.udec.cl/~friquelme/save.mcs
Posted 24 October 2007 - 10:35 PM
X0=1
numero de iteraciones=10
1
1.5
1.4166666666667
1.4142156859408
1.4142135623155
1.4142135626886
1.4142135620617
1.4142135624348
1.4142135628079
Done.
Press [<-] or
In CPlua.cpa shows this error
1
1.5
Rumtime error:
main:12: attempt to
perform arithmetic on a nil
value
Press [<-] or
I do not understand to be someone can help me
____________________________________________
no entiendo a que se debe alguien me puede ayudar
Posted 30 October 2007 - 06:48 PM
Apparently those who know more lua not help others o quizas sea por mi mal ingles
Posted 30 October 2007 - 08:29 PM
It gives nil for 1.41666 but not for 1.42666 nor 2.4166. Nil for 1.4144 but nor for 1.41999... If you use x^2+2, 1.41666 won't give nil... That is, on OS 3.02 (w/ CPLua .9E)require("cas")
f=cas("x^2-2")
print(f(a)) --replace a with a number
One way to resolve the problem would be:
By the way, I got a mem error while running the second code mixed with the first one multiple times with different values for d.require("cas")
a=input("x0=")
d=cas.diff(F,"x")
MZ={}
MZ=a --MZ won't change in the loop, so no need to put it into it
for n=2,ite do
--MZ[n]={} I can't see what this would be good for as MZ[n] is going to be overwritten in the very next line anyway...
MZ[n]=MZ[n-1]-cas(F .. "|x=" .. tostring(MZ[n-1]))/cas(d .. "|x=" .. tostring(MZ[n-1]))
print(MZ[n-1])
end
Posted 31 October 2007 - 04:43 AM
Up here all goes well
Muchas Gracias
