Hello
I want to solve a matrix with four unkown variables, i went to the variable manager and i saw that there was only one variable.
is that the problem?How can i addm more variables or solve the eqution?
thank you
Problem With A Matrix
maxxwell
, Dec 19 2007 04:59 PM
Posted 19 December 2007 - 04:59 PM
Posted 21 December 2007 - 02:36 AM
Try to make only one topic. posting two topics for the same thing will not get you double the answers.
Back in topic. a matrix is a variable, when you solve a linear system usin matrix algebra, the result is still a matrix. You need to extract the solution from that matrix..
So, if you want to solve a system and see every variable, you can do it using the
function on your 2D keyboard. you'll need to tap it several times to make it bigger (ie, to accomodate more ecuations)
As a example:
{ 2x + 3y =0 |
5y-12x = 2 |x,y
will give you x=-3/23 and y=2/23
In matrix form you can do:
rref( 2 3 0
-12 5 2
and you'll get
1 0 -3/23
0 1 2/23
As a example:
{ 2x + 3y =0 |
5y-12x = 2 |x,y
rref( 2 3 0
-12 5 2
and you'll get
1 0 -3/23
0 1 2/23
Posted 21 December 2007 - 02:34 PM
Sorry i'm i am stil a rookie in managing forum and thank you for the help
