@ LordNps
I think AFX's had 144 Kb on user ram (and the RAM chip is a 256K i think).
years ago when i was a "9860 is a crap" supporter i saw that many people said that the 9860 system RAM is almost 512Kb based on the chip specs. Is that true??.
AFX was programmed at the core on the good ol' days using weird things as assembler, for sure those guys did make a memory management system that fit their needs, as when you do grayscales and such.
I think that the 9860 was a step backwards on the casio line, isn't it supposed to be better than the AFX series? (in all aspects, not only far greater speed).
If they wanted a calculator for the school, an upgraded 9850 series is far enough to do the job. in fact, i think that more than a 570 ES on school is too much horsepower.
So they put a SD slot ("pro" feature) on a CAS-less and RAM-less calc without doing a newly revamped OS (as Classpad OS is)
Casio must release a "keyed" version of the classpad with a high res screen, Classpad's O.S and more RAM. I see the CP as the most powerful calc to date. And it will be at least when Nspires get serious programming abilities (i don't know if that's already done).
"offtopicking" end.
PS: sorry for the new nonexistant words
