less memory
Posted 10 April 2003 - 11:36 AM
my cfx9850gb+we seems to have less than my old cfx9850gb+.
why does it only have 28kb when my old one had 30kb???
what's the difference?
Posted 10 April 2003 - 02:50 PM
But anyway I have the FX 1.0........
Posted 11 April 2003 - 04:04 AM
I'm desperate though, so i'll keep looking.
Posted 11 April 2003 - 04:08 AM
Posted 11 April 2003 - 10:50 AM
It's a too high price......
I will find one FX 1.0 for you ( as you know the FX is a cheaper AFX )
Posted 11 April 2003 - 11:31 AM
still, i can get a good second hand pocket PC for that price.
Posted 11 April 2003 - 01:19 PM
[HTML HREF="http://www.taschenrechner.biz/prod-1845.html"]Dynatech Online[/HTML]
But I don't know if they ship outside europe.
Posted 11 April 2003 - 01:40 PM
Posted 11 April 2003 - 01:49 PM
Posted 11 April 2003 - 05:41 PM
the manual says that 28KB can be used, but I don't know what the maual of the old casio cfx9850gb+ says.i have notice something:
oh, well. that 2KB's don't make a huge difference for me.
Posted 11 April 2003 - 05:48 PM
These 2kb less probably means the restructered parts of the OS, allocating more for programs, and less for user data (maybe they fixed some bugs, and needed a few more k to run certain apps..)
Posted 12 April 2003 - 02:39 AM
I called Casio's australian distributor (the one that distributes to shops, not to the general public) and was told to try 4 stores. I rang 3, with no luck. the fourth i rang didn't have it, but told me the phone number of another store that specialised in calculators. they had it - for $399.95. TOO MUCH.
If i was spending that much, I could get a half-decent second hand Pocket PC which would do everything i needed.
I also noted that EVERY store i rang reccommended that I buy a TI instead. (with the exception of Casio's distributor). One store I asked about their range of TIs and found they stocked about 10 TIs. EVeryone knows casio is the best calculator in the world, being the original inventor of the calculator and all, so why are they so hard to get?????
Posted 13 April 2003 - 12:36 AM
Posted 13 April 2003 - 05:17 AM
reult: CFX9850.
NO AFX.
I looked on MSN shopping:
No casio calcs.
