Classpad 330 Electrical Calculations
Posted 02 September 2008 - 06:11 PM
example would be impedance calcualtions for single phase circuits:
(3+j7)+(6-j5) = take the answer and divide it by voltage which is expressed as a polar value ie (28kv<38)
This involves quick on the fly Pol to Rec conversions.
I can enter the rectangular values but am having difficulty converting to polar and entering polar values.
Any help would be appreciated.
Posted 03 September 2008 - 04:28 PM
Is there another forum that I should be asking?
Posted 03 September 2008 - 05:34 PM
I am new to the Classpad 330 and am having some difficulty entering polar calculations.
I don't know if I can help - but I'd like to figure this out. It's been 12+ years since I've done stuff like this and I'm pretty rusty.
CP seems to distinguish between complex-polar and real-polar values. For instance, if you use the expression comToPol(1+j) you get sqrt(2)e^(pi/4*j) -- whereas if you use the rectangular expression toPol([1,1]) you get [sqrt(2), <pi/4] (in radian mode)
The only way CP converts polar back to rectangular (that I can find) is toRect( ) and that insists on a vector argument, so (as far as I could tell) you can't convert from complex-polar to complex-rectangular.
I don't know if this will give you the type of answer you're looking for, but you could do the following (I'm in Std/Cplx/Rad):
compToPol((3+j7)+(6-j5)) ---> sqrt(85)e^(arctan(2/9)*j)
ans/(28e^(38*pi/180*j)) ---> (9/28 + j*1/14)*e^((-38*pi/180)*j)
from which you can read your result in polar form ( (9/28 + j*1/14), <-38)... though I confess I can't tell if it makes any sense.
If it doesn't, perhaps you can describe the calculations to me more so I can dig deeper. What I've been able to find via the web hasn't been terribly helpful.
Posted 04 September 2008 - 01:39 AM
I can use my HP50G+ for an answer but you do not have the ability to move the graph with the wisp of your pencil or easily plot table values. I had a TI-89 that I purchased which can also enter the values in and multiply on the fly between rectangular and polar values but it went missing, hence the 330 purchase.
In a nutshell I need to work with rectangular values I=V/(r+xl). v is expressed as a ang b theta (polar) number and denominator is in rectangular (a+bi) format.
This is a good calculator, I really do not see why this has to be hard? Casio must have thought this calculator may be used for electrical engineering?
Mike
Posted 04 September 2008 - 07:21 PM
You're right, it shouldn't have to be hard. It seems like it can't do exactly what you're wanting - though I tried to do what you suggested on an HP50G and was irritated because it wouldn't accept my angle in radians (even in radian mode).
Anyhow, I talked it over with a friend and we came up with a (possible) workaround. Take a look at it and see if it helps.
the theory here is that you call I( [44,<23] / ((3+j7) + (6-j5)) )
where I is input in the CP as follows:
define I(z)=re(z[1,1]+z[1,2]*i)+im(z[1,1]+z[1,2]*i)*i
it'll perform the division, remove it from the resulting vector, then separate the values into real and complex parts. And after you define it once you should be good to go from then on.
is it the same as having Casio take care of it for you? Nope... but hopefully it'll at lease solve your problem between now and whenever they release the next update (and we can hope that it'll be addressed in that update).
If, for some reason, that doesn't do what you need I'd be happy to keep trying - just describe the problem in detail. I'm enjoying the challenge!
Posted 05 September 2008 - 03:39 AM
http://www.flickr.co...864458/sizes/o/
Let me know if you are able to access the photo.
I appreciate the help your providing me.
Thanks,
Mike
Posted 05 September 2008 - 05:22 PM
You know, I think you should be able to use complex-exponential form (r*e^(theta*j)) to do the same thing and that would (I think) solve your problem. But I admit it is possible that I don't fully understand the use of that form. I've also found some results that are confusing me. I'll write more when I have a better idea of what I'm talking about.
in the meantime you might try using compToPol( ) -- that will convert complex-rectangular into polar form (exponential, but you can easily read r and theta). But I think the CP may have a bug in the way it simplifies polar (exponential) back to rectangular... so just be aware.
Posted 05 September 2008 - 05:49 PM
if you're willing to use the polar form r*e^(theta*j) then you should be able to do all the calculations you need. and you can convert back into this polar form by using the function compToPol( ).
BUT - I just figured out that that particular form is only defined for radians and therefore does funny things when you plug in degrees. So, if you use it, you need to convert your degree values to radians.
Sadly, another work-around. but perhaps one you would be somewhat comfortable with...
hopefully, Casio will tweak this in a future software release.
Posted 06 September 2008 - 12:27 AM
Thanks for your help btw,
Mike
Posted 09 September 2008 - 04:37 PM
Posted 01 October 2008 - 08:10 AM
I don't know if any forthcoming exhibition we have in next few months. Is there any?!
Guest_Guest_John_*_*
Posted 10 June 2010 - 02:09 AM
