Im typing in av program, GXAUSLM, into my fx-9750G but are running into some problems. Hope someone here can help me.
When i try to run det program "Syn Error" appears. Not sure whats wrong, most likely a typo, but have gone thru the program 4 times today and cant find any obvious typos. So i think i have missunderstod some symbols
Which line do i use?# On models with autodimensioning capability
# such as 9850GB+ and 9970G then replace the line:
# Seq(0,X,1,2A+2,1->List 1
# with the line:
# 2A+2->Dim List 1
Do i have to close these brackets?List Ans
>A
List Ans >B
Do i use the variabel X (under alpha key) or do i use the letter X (alpha - +)? Also the Y?J->X:K->Y:f4<>0=>Break
Next
A=1=>1->J:A=1=>1->X
The "/" is a divison sign right?Z/f4->M
Do i use the (-) or - button for the minus sign?Z-Mf4
Is this sign the one that is located under the SYBL key?A->X~Y:f4->M
(-) or - ?For A-1->E To 1 Step -1
I can´t see the "List->Mat( " in the program, why is it listed in the "instructions"?\i is the complex i
# * is the multiplication symbol which can be omitted
# List->Mat( is on optn|f1|f2
# _ represents the display symbol: shift|vars|f5
The entire program is located here:
http://spiderpixel.c...0g/cxgauslm.txt
Thanks
