I have been using my Classpad 300PLUS for maybe 2 years. Although I many times used solve option of it, last day it did not work. I wrote the following into classpad:
solve(sin(x)=1,x)
But it gave me a solution like
{x=360constn(1)+90}
But i don't want a solution like this. I want x=90 when it is in degree format. Also my calculator gives same kind of different results for equations including sin, cos, tan...
What is the problem friends? Please help me.
Classpad Gives Wrong Solutions
hasan_hzl
, Jun 07 2009 06:05 PM
Posted 07 June 2009 - 06:05 PM
Posted 08 June 2009 - 01:06 PM
It is completely right solution. constn(1) means any integer number. As we know the solution for sin(x)=1 is x=pi/2 + 2kpi. k here equal constn(1).
If you want to have only one specific solution, try solve(sin(x)=1,x)|0<x<180
Good luck. and welcome to the forum
Posted 10 June 2009 - 05:27 AM
This is correct I agree. But it also gives solution of the following equation for M in terms of tan(M^2). It has to iterate and give a solution for M. A number:) Not a olution like M = tan(M^2 bla bla...) When I write solve(equation,M,0) it gives correct one, i mean two M values. In the past it was not like this.
