Hello everybody!
I bought my ClassPad330 and downloaded the SDK to make Add-Ins for it.
The programming tutorial for SDK suggests me that I shall use the CPA and Windows EXE compiler, in Compiler Options. But in the drop-down list appears only one compiler: the "Default compiler".
When I tried to compiling anything, including source codes from other colleages, obviously appears a large list of errors. May be, I'm not using the right compiler... I need the other.
What can I do to compile anything successfully? (if its sure that the program has no errors...)
Or... where can I find the right compiler to add it into the SDK?
Thanks very much!
Right Compiler Missed In Sdk
eliusm
, Jul 27 2010 02:55 AM
Posted 27 July 2010 - 02:55 AM
Posted 27 July 2010 - 10:48 PM
Dear friends!
I found all what I'm looking for here:
http://cpsdk.com/
I don't know, why the SDK from the classpad.tk page are not the latest version, and had no compiler kernels.
This problem is solutionated.
Thanks very much.
http://cpsdk.com/
Thanks very much.
