Well the screen is all missed up. The touch of the screen works, but what the calc displays is like cuts in the screen from the previous screen it was showing, lines and just like bits and pieces of the screen. Only thing i can think of that did this was, after tutor i went to the beach and it was in my bag. Was also a hot day.
Tried resetting it, updating it and at one point it went back to normal for a minute. Then it stuffed up again.
Casio Classpad 330 Display Problem
bowasd
, Jan 18 2011 10:05 AM
Posted 18 January 2011 - 10:05 AM
Posted 20 January 2011 - 03:11 PM
Try changing the batteries.
If that didn't work, try applying some violence to the calc, for example gently(!) drop it from a height of 1 meter on the ground. I'm not kidding, in the old ClassPad 300 times some people had problems like you which solved by violence: See here and here and here as examples. Warning: No Guaranty of this working.
- smkhalili likes this
