Best Answer pan.gejt , 26 November 2016 - 07:57 PM
Recall X and Y to get the magnitude and the angle.
Math notice: Your result is incorrect. This operation (400)/(Pol(0.7-15,1.9+1.9)) is not defined because you cannot perform calculation "constant/(magnitude,angle)". How you can divide the magnitude and the angle simultaneously? You can perform Pol(X, Y) only. You enter 2 parameters and your result is also 2 parameters.
The magnitude is 14.8 and the angle is 165.1 degree.
Go to the full post
