I was trying to get Natural Display on my Casio fx-9750Gii Calculator and during the flashing process it said there was a problem flashing and it stopped. Before i began the flash I believe my calculator's version was either 02.04.0701 or 02.04.0700. I guess something bad happened during the process because now my calculator's version is 02.04.0201 . How can i fix this? I have tried to find a fix for the past few weeks with no luck.
Firmware flashing failure Casio fx-9750Gii (Help!)
Posted 07 December 2017 - 12:48 AM
Posted 13 December 2017 - 04:17 PM
You should have made a backup file of your calc before flashing, if you did you should try to upload that to your calc. Otherwise you could go and try to find that os version on the internet and try uploading that. However, if there isn't a difference between the versions then I wouldn't risk it. There is always a chance (very small) it will fry your calc when flashing.
I tried doing this and eventually gave up (They patched this exploit with the new os's, probably what happen to you) and got the fx-9860gii.
Good luck
Also tagged with one or more of these keywords: Flash, Casio, 9750GII, Natural Display, Flashing, Firmware, Mods, Mod, Help
Programming →
Casio Basic →
ASCII conversion table on fx G seriesStarted by Just_A_Noob_Here , 20 Jul 2024 ![]() |
Calculators →
Casio CFX/AFX/FX/Prizm →
Audio player programStarted by NIPro , 22 May 2024 ![]() |
![]() Where i can buy FA-123 cable for cheap?Started by NIPro , 23 Mar 2024 ![]() |
Calculators →
Zoom on Casio fx-9860IIIStarted by kozardii , 12 Jan 2024 ![]() |
Calculators →
The fx-800DE CW changes everything to the ClasswizStarted by critor , 25 Jul 2022 ![]() |
