GCD and LCM [fx-5800P]
#1 slugrustle
slugrustle
  • 8 posts
  • Gender:Not Telling
    fx-5800P
    fx-9860GII SD
Posted 24 November 2018 - 05:15 PM
Both programs below prompt the user for at least 2 input numbers and accept up to 27 inputs. After calculating, they display the result on the first line of the display and the input arguments on the next three lines of the display. You can scroll through the inputs if there are more than 3 of them.
I wrote these programs after finding a neat application for least common factor in my day job writing microcontroller firmware. I also put them on GitHub along with .pdf versions of the program listings. See https://slugrustle.github.io/
Greatest Common Divisor / Greatest Common Factor
0➔DimZ:
27➔DimZ:
0➔A:
”ENTER -1 AFTER  LAST INPUT”:
While 1:
   ”NUMBER”?➔B:
   B=-1⇒Break:
   If B≠Int(B):
      Then Cls:
      ”NUMBER MUST BE  AN INTEGER”:
      Stop:
   IfEnd:
   If B<1 Or B≥1ₓ₁₀10:
      Then Cls:
      ”NUMBER MUST BE  >0 And <1ₓ₁₀10”:
      Stop:
   IfEnd:
   A+1➔A:
   If A≤27:
      Then B➔Z[A]:
   Else Cls:
      ”SUPPORTS AT MOST27 NUMBERS”:
      Stop:
   IfEnd:
WhileEnd:
If A<2:
   Then Cls:
   ”REQUIRES 2 OR   MORE NUMBERS”:
   Stop:
IfEnd:
A➔D:
Z[D]➔B:
For D−1➔A To 1 Step -1:
   Z[A]➔C:
   While B≠C:
      If B≥C:
         Then B−C×Int(B÷C)➔B:
         B=0⇒C➔B:
      Else C−B×Int(C÷B)➔C:
         C=0⇒B➔C:
      IfEnd:
   WhileEnd:
Next:
1➔C:
Int(D÷3)➔E:
D−3×E>0⇒E+1➔E:
Lbl 1:
Cls:
Locate 1,1,B:
Locate 12,1,C:
Locate 13,1,”:”:
Locate 14,1,E:
3×(C−1)+1➔A:
Locate 1,2,Z[A]:
A+1≤D⇒Locate 1,3,Z[A+1]:
A+2≤D⇒Locate 1,4,Z[A+2]:
While 1:
   Getkey➔F:
   If F=34 Or F=73:
      Then Cls:
      ”DONE”:
      Stop:
   IfEnd:
   If F=77 Or F=84 Or F=86 Or F=47:
      Then C+1➔C:
      C>E⇒1➔C:
      Goto 1:
   IfEnd:
   If F=67 Or F=83 Or F=85:
      Then C−1➔C:
      C<1⇒E➔C:
      Goto 1:
   IfEnd:
WhileEnd
Program Outline
  • 0➔DimZ:27➔DimZ: Set up memory for extra variables Z[α] where α∈[1,27].
  • 0➔A: through A➔D: User input of arguments for GCD(Z[1], ..., Z[D]). D∈[2,27].
  • Z[D]➔B: through Next: Evaluate B = GCD(Z[1],   ..., Z[D]). Uses GCD(β,γ,δ,ε) = GCD(GCD(GCD(β,γ),δ),ε).
  • 1➔C: to end of program: Display result and inputs.
Variable Descriptions
A: Index into extra variable memory.
B: User input and GCD evaluation.
C: GCD evaluation and number of displayed input argument page.
D: Number of input arguments.
E: Number of input argument display pages (3 inputs per page).
F: Identifier of most recently pressed key.
Notes
  • ”ENTER...":, "NUMBER...":, "SUPPORTS...":, "REQUIRES...": The weird spacing prevents text wrapping from occurring in the middle of a word.
  • If B<1 Or B≥1ₓ₁₀10: The fx-5800P can only represent numbers on the range [−1ₓ₁₀10,1ₓ₁₀10] as exact integers.
  • If F=34 Or F=73: Pressing DEL (34) or EXIT (73) ends the program.
  • If F=77 Or F=84 Or F=86 Or F=47: Pressing + (77), ▲ (84), ▶ (86), or EXE (47) cycles to the next input argument display page.
  • If F=67 Or F=83 Or F=85: Pressing − (67), ◀ (83), or ▼ (85) cycles to the previous input argument display page.
Least Common Multiple / Least Common Factor
0➔DimZ:
27➔DimZ:
0➔A:
While 1:
   ”NUMBER”?➔B:
   B=-1⇒Break:
   If B≠Int(B):
      Then Cls:
      Stop:
   IfEnd:
   If B<1 Or B≥1ₓ₁₀10:
      Then Cls:
      Stop:
   IfEnd:
   A+1➔A:
   If A≤27:
      Then B➔Z[A]:
   Else Cls:
      Stop:
   IfEnd:
WhileEnd:
If A<2:
   Then Cls:
   Stop:
IfEnd:
A➔D:
Z[D]➔B:
   B➔E:
   Z[A]➔C:
   While B≠C:
      If B≥C:
         B=0⇒C➔B:
         C=0⇒B➔C:
      IfEnd:
   WhileEnd:
   If E≥Z[A]:
      Then (E÷B)×Z[A]➔B:
   Else (Z[A]÷B)×E➔B:
   IfEnd:
   If B≥1ₓ₁₀10:
      Then Cls:
      ”OVERFLOW”:
      Stop:
   IfEnd:
Next:
Int(D÷3)➔E:
D−3×E>0⇒E+1➔E:
1➔C:
Lbl 1:
Cls:
Locate 1,1,B:
Locate 12,1,C:
Locate 13,1,”:”:
Locate 14,1,E:
3×(C−1)+1➔A:
Locate 1,2,Z[A]:
A+1≤D ⇒ Locate 1,3,Z[A+1]:
A+2≤D ⇒ Locate 1,4,Z[A+2]:
While 1:
   Getkey➔F:
   If F=34 Or F=73:
      Then Cls:
      ”DONE”:
      Stop:
   IfEnd:
   If F=84 Or F=86 Or F=77 Or F=47:
      Then C+1➔C:
      C>E⇒1➔C:
      Goto 1:
   IfEnd:
   If F=83 Or F=85 Or F=67:
      Then C−1➔C:
      C<1⇒E➔C:
      Goto 1:
   IfEnd:
WhileEnd
Program Outline
  • 0➔A: through A➔D: User input of arguments for LCM(Z[1], ..., Z[D]). D∈[2,27].
  • Z[D]➔B: through Next: Evaluate B = LCM(Z[1], ..., Z[D]). Uses LCM(β,γ) = (β×γ)÷GCD(β,γ) = (β÷GCD(β,γ))×γ = (γ÷GCD(β,γ))×β and LCM(β,γ,δ,ε) = LCM(LCM(LCM(β,γ),δ),ε).
B: User input and LCM evaluation.
C: LCM evaluation and number of displayed input argument page.
E: LCM evaluation and number of input argument display pages (3 inputs per page).
Notes
  • If B<1 Or B≥1ₓ₁₀10:, If B≥1ₓ₁₀10: The fx-5800P can only represent numbers on the range [−1ₓ₁₀10,1ₓ₁₀10] as exact integers.
  • If F=84 Or F=86 Or F=77 Or F=47: Pressing ▲ (84), ▶ (86), + (77), or EXE (47) cycles to the next input argument display page.
  • If F=83 Or F=85 Or F=67: Pressing ◀ (83), ▼ (85), or − (67) cycles to the previous input argument display page.
#2 slugrustle
slugrustle
  • 8 posts
    fx-5800P
    fx-9860GII SD
Posted 12 December 2018 - 04:50 AM
I have also added an integer factorization program called FACTOR, which is described in a reply to the thread https://community.ca...casio-fx-5800p/
CCE and CCL files for GCD, LCM, and FACTOR are available at https://slugrustle.github.io/ and https://github.com/s.../fx-5800P_progs. These files can be used with with Takumako's CcEditor, CcLinker, and USB Dongle, about which see https://cclinker.web.fc2.com/
#3 Tritonio
Tritonio
  • 77 posts
    fx-5800P, fx-991ES+, fx-991EX, HP Prime, fx-9750GIII, fx-3650P II
Posted 10 September 2019 - 02:14 PM
Oh this is a fast version that uses the Wheeler factorization or whatever it's called? I went ahead and made some slow but simple LCM GCD progs but I could have typed these in instead.
#4 CalcLoverHK
CalcLoverHK
  • 270 posts
  • Interests:FPS games, C.Basic
    fx-50FHII (2019/1/30)
    fx-991ESPLUS-2 (2023/12/22)
    fx-3650PII (2022/1/15)
    fx-9750GIII
    fx-9750GIII-WE
    fx-9860G Slim
    fx-9860GIISD
    fx-9860GIISD-2
    fx-CG20CN
    fx-CG50
    fx-CP400
    Graph Math+
Posted 10 September 2019 - 02:17 PM
Oh, I forgot to tell you this post. I have looked a bit only :P
